Removing Carpet?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JasonJump, Sep 26, 2011.
  1. May 5, 2019 at 1:25 PM
    Turbo45
    Turbo45 Member
    British Columbia
    2010 Tacoma 6 speed
    where did you get the black carpet? does the newer 2nd gen carpet fit in the older trucks?
  2. May 5, 2019 at 1:48 PM
    zachshere
    zachshere Well-Known Member
    What brand are your seat covers? Do they fit over stock seat covers?
  3. May 6, 2019 at 6:08 AM
    AuDigger
    AuDigger Well-Known Member
    1995.5 Evergreen Pearl 5-lug Extracab
    Those aren't covers. They are Katzkin leather.
    dressed in black and zachshere like this.
  4. May 6, 2019 at 6:32 AM
    zachshere
    they are awesome!
  5. May 7, 2019 at 5:48 AM
    AuDigger
    Thanks, I got a great deal on them. They are actually for a 2009-11 (mines a 2007) but they fit great. They just have the side airbag tab which mine doesn't have.
  6. May 7, 2019 at 7:05 AM
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    I removed my seats to put heaters in them, I just unbolted the seats, unplugged the wire harness, and pulled them out, I never even unplugged the battery, it's a 06 so it doesn't have air bags in the seats, atleast I didn't see any, I would love to get black carpet, is this something that is from the dealer only?
  7. May 7, 2019 at 9:14 AM
    zachshere
    I have Clazzio covers which are nice but nothing like yours!
  8. May 7, 2019 at 11:56 AM
    AuDigger
    Got the carpet from stockinteriors.com. A royal pain to put in - plan on a day.
  9. May 7, 2019 at 12:21 PM
    christian06
    Cali
    Why was it such a pain, and how much was it
  10. May 7, 2019 at 1:30 PM
    christian06
    Cali
    Did u get the extra mass backing or just the poly backing and the jute pad?
  11. May 7, 2019 at 2:53 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I put the All Weather Flooring in my truck. There’s a thread in here on it with part numbers if you search for it.
    zachshere likes this.
  12. May 7, 2019 at 2:54 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I tried aftermarket carpet first...that was a waste of time and money. Took it out and put in the flooring.
  13. May 7, 2019 at 4:42 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    What brand carpet did u try that u didnt like?
  14. May 7, 2019 at 4:49 PM
    81shark
    81shark Well-Known Member
    Pretty easy. I think there were a couple of bolts inside the center console. My memory is fuzzy on that. Defiantly a screw under the cup holder . at least on the manual. Kick panels unscrew, side rails pop off. I have an access and took off the rear seats. Super easy
  15. May 7, 2019 at 4:58 PM
    #35
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Some high end extra padding crap bought through RockAuto. It was molded for the Tacoma but still needed cutting and that sucked and the extra thickness made none of the panels fit right.
    Buy a Toyota carpet or rubber flooring. It fits, has clips and is a whole lot easier.
  16. May 8, 2019 at 5:31 AM
    #36
    AuDigger
    I didn't get the mass backing. It just takes time and patience to install. I took out everything including the lower B & C panels. It is somewhat molded -nowhere near like the factory carpet. The cutouts aren't there, so you have to cutout for the console, the storage bins under the rear seats, the holes to mount everything, etc. But, for under $200, it was worth the time.
    eherlihy and christian06[QUOTED] like this.
  17. May 8, 2019 at 5:32 AM
    #37
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    @EatSleepTacos stripped the carpet out if his truck recently. He put down some bedliner instead of the carpet. Looked really clean
  18. May 8, 2019 at 7:10 AM
    #38
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I don’t see how that would work well with all the wiring and floor air vent duct.
  19. Jun 6, 2019 at 10:06 AM
    #39
    chavab_1
    chavab_1 Member
    2015 Silver Tacoma TRD 4X4
    The interior came out real nice!!
    What did you do with the retainer hooks and grommets for the floormats? I want to replace my carpet as well and this is the only thing I have to figure out. I don't know if I can remove and re-use the original ones or if I have to replace them. My truck has twist-lock style retainers.
  20. Jun 7, 2019 at 7:00 AM
    #40
    AuDigger
    I have the older style ones (not twist-lock) so I just cut a small slit in the carpet to push the retainer hook back in to hold the mats in place. They haven't shifted at all since I installed them.
    chavab_1 likes this.
