Removing chrome badges?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevine, Nov 9, 2013.
  1. Nov 9, 2013 at 1:23 PM
    kevine
    kevine [OP] Well-Known Member
    Valencia, CA
    Tacoma Pre-Runner
    tinted windows
    I'm considering removing the badges. I've heard of using a blow dryer with string. Just wondering if fishing string works or should I be doing something totally different. Thx
  2. Nov 9, 2013 at 1:34 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I squirt 3M cleaner [​IMG] 3-4-5x along the top of the emblem, let it work in, squirt more along the top (don't be in a hurry) using your fingers just lift a corner of the emblem and squirt more cleaner along the top. Take your time and let the cleaner do the work. The emblems come right off and any left over on the truck just use your fingernail to remove. No wires or hairdryers
  3. Nov 9, 2013 at 3:24 PM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    I used a heat gun and some old Berkley line I had on an old reel not sure what test it was more than 10lb I think. The line broke a few times but worked fine.
  4. Nov 9, 2013 at 3:27 PM
    rickcrna
    rickcrna Well-Known Member
    Rick
    Vancouver, WA
    '13 AC SR5 4WD I4 Auto MGM
    There is already so much information on here about de-badging. Please use the search function and read.
  5. Nov 9, 2013 at 4:46 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Offering the power of suggestion is nice. But maybe you could have did some searching yourself and pulled up a thread or two for the OP. Because really, your post adds nothing to the thread. It's more of a hindrance than a help.
    Like this....http://www.tacomaworld.com/forum/2nd-gen-tacomas/283023-well-all-my-chrome-finally-gone.html
  6. Nov 9, 2013 at 5:59 PM
    rickcrna
    Rick
    Vancouver, WA
    My post was not meant to be a "hindrance" as you claim. However, I find your response very offensive and rather idiotic.
  7. Nov 9, 2013 at 9:21 PM
    kevine
    Valencia, CA
    Tacoma Pre-Runner
    tinted windows
    Thanks guys, and I apologize for my laziness for not using the search function. I had used it before and that's how I found out about the heat gun/blow dryer/string method. Thanks again Steve for the adhesive removal tip. I have to assume that it did not affect the finish of the paint.
  8. Nov 9, 2013 at 10:00 PM
    jw1983
    Alberta
    So I guess that it's okay for you to point out to someone in being lazy for not using the search function. I guess you don't like it that someone did it to you. Kind of hypocritical. So stop calling the kettle black, when your tea pot.
