Removing color match tire wells
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Haskett039, Mar 19, 2012.
  1. Mar 19, 2012 at 7:03 PM
    Haskett039
    Haskett039 [OP] Well-Known Member
    Rob
    Ontario, Canada
    2012 TRD Alpine White
    Hey all i tried to post this earlier but it didn't work for some reason...
    Hey guys, as luck would have it 3 days after i picked up my brand new 2012 Taco TRD i had a deer run out onto the road, head butt the side of the truck and then run away ! Now i have a body guy that said he can work the dent out of the rear panel but he needs me to get the plastic color match tire well cover off. Has anybody removed one of these yet?? Is it just bolt on, or are there clips and glue or something i should worry about, i noticed on mine that there is a black rubber trim (gasket) along the side ??
    ANY HELP WOULD BE GREAT...
    Thanks
  2. Mar 19, 2012 at 8:21 PM
    ajan246
    ajan246 Well-Known Member
    Orange County, CA
    2012 Access PreRunner V6 2WD
    there are 7 or 8 orange christmas tree clips that hold this on. If you're gentle you can pry it off working your way around the fender. These clips are pretty brittle and break easily, so just be careful.
  3. Mar 19, 2012 at 8:37 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    You're about guaranteed to break those clips. Fastenal and toyota carry extras. Couple bolts underneath too.
    Check the expanded parts diagram thread for a picture with part numbers.
