REMOVING DECALS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sooner, Jul 14, 2011.
  1. Jul 14, 2011 at 1:40 AM
    sooner
    sooner [OP] Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    has anyone removed there badging and how is it done without screwing up the paint?
  2. Jul 14, 2011 at 1:48 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    take some fishing line put it behind them hold both ends of the line and pull it from one side of the badge to the other . i took any remaining glue off with bug and tar remover.
  3. Jul 14, 2011 at 1:50 AM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    Badges do that way^
    For decals take a blow dryer and heat them up and peal them off,
    Then use bug and tar remover to get rid of the adhesive stuck to the paint
  4. Jul 14, 2011 at 2:01 AM
    sooner
    TX
    2011-4X4-LONGBED
    thanks guys
  5. Jul 14, 2011 at 2:02 AM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    I used a blow dryer for the emblems too. Made it way easier.
  6. Jul 14, 2011 at 2:15 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    I used floss and goo gone
  7. Jul 14, 2011 at 4:22 PM
    daggertats
    arden nc
    hes in texas..........its so hot there he wont need the blowdryer....badges may just fall off on their own....lol
  8. Jul 14, 2011 at 4:24 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    if you're using a hair dryer to heat them up be careful not to overheat them, doing so could cause the adhesive to fuse to the paint and then you'll have a real mess!
  9. Jul 14, 2011 at 4:45 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    i used a cvs card... make sure you wax the spot where the decals were
