Removing driver seat to install amp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reidmn, Jan 12, 2011.
  1. Jan 12, 2011 at 7:00 PM
    reidmn
    reidmn [OP] New Member
    Oahu, Hawaii
    10 TRD sport pyrite mica
    hey all,
    i just bought a 4 channel amp that i want to place under my driver side seat. now, just by looking at the seat i only see 4 bolts holding them down in the corners. seems easy enough, but just wanted to see if there's anything else i should be aware of before i begin? ex. airbags? thanks!
    oh yeah, i have a 2010 TRD SPORT double cab.
  2. Jan 12, 2011 at 8:19 PM
    Gitmo
    Gitmo Well-Known Member
    Justin
    Once you unscrew the 4 bolts on the seat there will be 3 cables that need to be unplugged under the seat. I know one of them deals with the airbag light/system and not sure about the other two. Also, when I tried removing the black one, it was clipped to the bottom of the seat permanently if I remember correctly?...so I just snapped it off since it really doesn't matter. Here are some pics of the amp I installed last summer...
    Unfortunately I never took pics of underneath the seat..
  3. Jan 13, 2011 at 12:16 AM
    reidmn
    Oahu, Hawaii
    Ok that's what I was thinking it was gonna be. One more question, where did u put your ground? I was thinking I could just sand one of the 4 bolt hole areas and ground it there? Think that would be cool? Btw thanks for posting pics too.
    Oh, and I see you took of the center console trims. Did they just snap right off or is there some kind of process to removing it ( I plan to run my signal and remote wires along the center trim.). Thanks!
  4. Jan 13, 2011 at 12:36 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i grounded mine to one of my seat bolts
  5. Jan 13, 2011 at 1:55 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    As a general precaution you should remove the battery ground before unplugging the airbag connector. This would be the yellow connector. I installed my amp in the same place with no problems.
  6. Jan 13, 2011 at 2:55 AM
    Gitmo
    Justin
    ^ This too.
    The trim pieces on the door sill just pop out. It might sound like they just broke when you pop them out but it's just how they are designed. As for the center console, the silver piece around the shifter just pops straight up/out. I use the "pencil tray" (that's what I use it for during school) to grip and pull it up. Then there's a quite a few screws that hold the center console in if you are thinking about removing that completely.
    EDIT:
    Oh, I grounded the amp wire to one of the screws in the door sill area where there were some other wires grounded. Doesn't matter where you ground it as long as it's cleaned up like you were planning on doing :).
  7. Jan 13, 2011 at 3:01 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    There are a couple little loose springs in the airbag connector that are easy to lose when you disconnect it. Put 'em in a ziploc or somesuch until ready to reassemble.
  8. Jan 13, 2011 at 4:11 AM
    JKD
    JKD Well-Known Member
    In your 2010, it isn't just airbag *sensors* you're disconnecting, it is the side impact airbags that are contained in the seatback. Be reasonably cautious with the seat and the connectors.
  9. Jan 13, 2011 at 4:39 AM
    NoMallCrawlTaco
    NoMallCrawlTaco © "HELL FUCK YEAH!" © COPYRIGHT FOR MY PROTECTION!
    Arizona
    4" Camburgs Icon AAL 3 Pac BLHM Tacoshi Grill More to come...
    dude, loose the steering wheel cover, looks kinda...!
