Removing Drivers Side Rear Seat-Back In A DC?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IrishPilot, Mar 5, 2010.
  1. Mar 5, 2010 at 7:00 PM
    IrishPilot
    IrishPilot [OP] Well-Known Member
    MN
    09 TRD Off-Road 4x4 Double Cab
    Just wondering if there is a way to remove the seat back on the drivers side rear of a Double Cab. I dont want to remove the entire back seat, just need to get the 40% of the 60/40 out.
    Thoughts or suggestions?
  2. Mar 5, 2010 at 7:06 PM
    IrishPilot
    MN
    Dang...and the full back seat is a bearcat to remove if memory serves.
  3. Mar 7, 2010 at 10:03 AM
    IrishPilot
    MN
  4. Mar 7, 2010 at 12:23 PM
    IrishPilot
    MN
    For the record, this was EXTREMELY easy to do. Simply lift the bottom part of seat, fold back of seat down, remove two 14mm bolts holding back of seat in, and pull seat back out.
  5. Mar 7, 2010 at 12:49 PM
    matt86
    matt86 Well-Known Member
    NC
    2008 Tacoma SR5 4x4
    Just curious... What are you going to do with the half with no seat in it?
  6. Mar 7, 2010 at 1:04 PM
    IrishPilot
    MN
    I just removed the seat back on the drivers rear side to get at the back wall some for some sub work and sound deadening. I put the seat back back in afterwards. I just didnt want to have to tear the WHOLE 60/40 out when I only needed to get behind the 40 ;)
  7. Apr 24, 2010 at 11:25 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    Is it required to remove the seat back to remove the compartments and expose the back wall? I removed the 3 bolts inside the 40/side but can't pull the compartment out.
    I need to get at it for some deadening.
  8. Apr 24, 2010 at 11:38 AM
    Crownedcustoms
    Crownedcustoms Well-Known Member
    Gilbert
    07 dc 4x4 fox coilovers 20's & toyo mudders
    Fox coil-overs, Fox shocks, 20" Helo wheels, blowthough, Jl and focal system, Grillcraft grill, Toyo Mud terrains
    One side had to come out before the other because they overlap each other and clip together in the moddle. There are also other clips in addition to the bolts. Your gonna have to give a careful yank or two to get it out. If memory serves me you shouldn't have to remove the rear seat. Good luck!:)
  9. Apr 24, 2010 at 2:00 PM
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    Got it - thanks! Of course I broke a few of those white clips and it never goes back in the same way it came out.
    Oh well...it's deadened.
