Removing drivers side seat and SRS
Discussion in 'Audio & Video' started by ZonKs, Dec 26, 2007.
  1. Dec 26, 2007 at 8:23 AM
    ZonKs
    ZonKs [OP] Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    Today im planning on removing my drivers side seat temporarily to install an amp. Ive been told that this could activate the SRS. Ive seen pics here where people have removed their seats. How did you sidestep the Safety Restraint System?
    Thanks,
    Ted
  2. Dec 26, 2007 at 9:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'd be curious myself.... I'll be installing heated seats here within the next couple weeks and will need to remove the seat completely. I just haven't looked in the service manuals yet to look at what's involved. There are online service manuals you can download.....
    Get them here:
    http://www.toyotanation.com/forum/showthread.php?t=186199
  3. Dec 31, 2007 at 9:44 AM
    PatheticJoe
    PatheticJoe Well-Known Member
    Sacramento, CA
    07 Prerunner SR5 TRD Sport - Access Cab
    Disconnect the negative battery terminal before working on the truck and you won't have a problem.
  4. Dec 31, 2007 at 12:05 PM
    socko3161
    socko3161 Well-Known Member
    There should be a little yellow or orange clip right under the dash that is the power to the SRS... In the fire deptartment we splice into them and set the air bags off all the time, I would think if you would temporaily cut the power to the actual bag that it shouldn't go off but disconnecting your Neg. Terminal would be your best bet... even though it is a bitch to reprogram your radio and all
  5. Dec 31, 2007 at 1:38 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    when i put my hideaway brain for my head unit under my passenger side seat, all i did was remove the bolts and leaned it to the rear of the truck...but then again i have the DC.
  6. Jan 3, 2008 at 4:34 AM
    colttsi
    colttsi Well-Known Member
    There is something you should know before playing with airbags. There are condensers that need to be drained of their voltage before you play with those so the best thing to do is disconnect both negative and positive battery terminals and put them together so that you unload these condensers, then you can start to remove stuff.
    When we used to play with airbags, we always had a sort of a grounding device that prevented us from discharging static electricity towards the airbag.
    You really have to be careful.
