Removing drop, adding lift - '19 Sport 4WD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRSAndrew, Dec 4, 2019.
  1. Dec 4, 2019 at 4:26 AM
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    1) The shop that put on the drop threw out the stock parts.
    2) SOS Performance told me the OEM parts thrown out are: Front shock spring perches. Front snubbers, rear u bolts bottom plates, snubbers, rear shackles
    3) I want to do a small lift (1-2")
    If I want to do a slight lift, what would the lift come with out of these vs. what do I need to source myself?
    Any help is appreciated!
  2. Dec 4, 2019 at 6:27 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Depends on the type of lift. A spacer block lift will most likely just come with spacers and blocks. A true suspension lift will likely come with new front struts with springs and different leaf packs for the rear. You can talk with @HeadStrong Off-Road since they can try to help you piece something together. I would think you’d have to find new rear shackles regardless
  3. Dec 13, 2019 at 8:54 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much for the recommendation @Anchovy !! :cheers:
    Anchovy[QUOTED] likes this.
