Removing EGR from 4WD 2TR-FE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RiverRatMatt, May 15, 2011.
  1. May 15, 2011 at 4:48 PM
    RiverRatMatt
    RiverRatMatt [OP] Member
    Idaho
    2010 Tacoma 2.7L 4x4 Manual Transmision
    1986 Front Tow Hook Yellow Wire Mod Fan squeak fix
    I have a 2010 4x4 Tacoma with the 2.7L 2TR-FE.
    It will never need to pass emissions tests, and I'm looking to get a little bit more power out of it. I have a K&N Air filter, but I haven't had it very long and will probably go back to a normal air filter, because I hear it can gum up the MAF and cause issues over time.
    Removing the EGR system seems like the next logical step to increase torque, but I'm having trouble finding info on what all would have to be done.
    Thanks for any help!
  2. May 15, 2011 at 6:32 PM
    JKD
    JKD Well-Known Member
    I really don't see what removing a properly functioning EGR would do to increase torque on any engine. When you are at high throttle, EGR shuts off anyway.
    Lack of a functioning EGR will cause the computer to set a trouble code and probably illuminate the CEL.
    It seems to me that the next logical step would be the exhaust. I'd leave the EGR alone.
  3. May 15, 2011 at 6:34 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    Are you sure that engine has an EGR system?
    G
  4. May 15, 2011 at 6:40 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I think they call it an air switching valve in the service manual :notsure:
  5. May 15, 2011 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No EGR valve on the newer engines....
  6. May 15, 2011 at 6:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And at idle. The EGR is used to reduce cumbustion chamber temps, by introducing exhaust gasses into the CC at part throttle settings. This is only on vehicles that have them. IIRC, The last Tacoma engine to run with an EGR valve is the 2.7 in the first gens.
  7. May 15, 2011 at 7:29 PM
    RiverRatMatt
    Idaho
    That doesn't make any sense; EGR recirculates hot exhaust gasses into the intake to recombust them, ensuring that all the 'bad' stuff is burned.
    EGR, as far as I have always known, reduces power, gas mileage, etc, but allows engines to pass California's stupid emissions laws.
    Also I'm not talking about full throttle power, and the engine has plenty of power in 4Low where I need it most. I'm just looking to improve around town performance a little bit and possibly increase gas mileage.
    Also, I'm not willing to change the factory exhaust system. Only intake mod I'm likely to do would be a snorkel, but I don't need one at this point.
  8. May 15, 2011 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What doesnt "Make sense"?
  9. May 15, 2011 at 7:46 PM
    justinhw
    justinhw Well-Known Member
    Turlock, CA
    06 Regular Cab 4x4 2TR-FE
    agreed
    the 2tr-fe doesn't have an an EGR system. There is a pump for the air injection system which is smog equipment, but it's not belt driven and (correct me if I'm wrong) I don't think it uses too much current.
  10. May 15, 2011 at 9:52 PM
    RiverRatMatt
    Idaho
    Ok, that makes sense to me. Interesting.
  11. May 15, 2011 at 10:27 PM
    justinhw
    Turlock, CA
    you actually got me thinking, and I'm not sure about the operation of the system- e.g. if it is pumping air into the exhaust constantly. I have a feeling not because there is 1. an air switching valve and 2. a vacuum line connected to a pressure sensor on the intake.
    I've read somewhere that is mainly used during warm-up operation but I'm not sure, maybe someone else can shed some light?
    References:
  12. May 15, 2011 at 10:31 PM
    justinhw
    Turlock, CA
    anyways that's off topic, apologies
  13. May 15, 2011 at 10:37 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Regear it or get a supercharger.
