removing emblems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maysville06, Jan 30, 2012.
  1. Jan 30, 2012 at 3:11 PM
    Maysville06
    Maysville06 [OP] Well-Known Member
    Bruce
    Georgia
    Pre-runner SR5 Long bed
    K&N Cold Air Intake, Flowmaster Exhaust,20% window tint all around, Weather tec rear floor mats, Blacked out badges,Mudflaps removed,JDM black aftermarket headlights,black grille, running boards removed,Nightshaded tail lights,TRD Sport suspension,3in leveling kit in front,2in blocks in the rear,blacked out rims, Reese class III receiver hitch
    Does anyone have a tutorial on removing emblems they would be willing to share?
  2. Jan 30, 2012 at 3:15 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    A little searching oughtta yield a ton of hits. Hair dryer for heat and saw along back of emblem with fishing line through the goo. Clean and wax area and viola.
  3. Jan 30, 2012 at 3:20 PM
    TJGARZA84
    TJGARZA84 Well-Known Member
    TIM
    SAN ANTONIO
    2012 TOYOTA TACOMA PRERUNNER SR5 - BLACK
    TINT - 20% FRONT - 5% REAR 3 INCH LIFT PAINT TO MATCH GRILL AND REAR BUMPER REMOVED ALL EMBLEMS
  4. Jan 30, 2012 at 3:29 PM
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
    Heat gun and dental floss have always worked good for me. Just take your time and it will be fine. Goo gone helps remove any left over glue and then clean and wax to protect the paint and enjoy.
  5. Jan 30, 2012 at 4:25 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    This^^^^
    You can find pictures if needed with a little searching.
  6. Jan 30, 2012 at 4:31 PM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Yupp just like the others are saying, searching works well. But Other then being a dick ill let you know how I did it...
    -Got my heat gun out and heated up the double sided sticky tape. (Make sure not to over heat bc it will destroy your paint job and clear coat on the truck)
    -Grab some thick fishing line or floss (I used fishing line) and work it behind the emblems. Once its behind, move the fishing line/floss in a sawing motion back and forth.
    -Do not pry on the emblem with anything unless you intend on ruining your paint. Just take your time and do the job right.
    -Once emblems are removed get some goo gone and remove the rest of the adhesive. If there is a "ghost" emblem still present, get some fine rubbing compound and use it lightly on those areas. Once you have it all removed, finish with a nice waxing job!!
    -Grab a beer/drink of choice and enjoy your nice new "DE-BADGED" tacoma!
    goodluck man.
