Removing epoxy lacquer on a Saxophone
Discussion in 'Sports, Hobbies & Interests' started by skb7527, Nov 13, 2012.
  1. Nov 13, 2012 at 11:29 AM
    skb7527
    skb7527 [OP] Political Correctness Sucks!
    Scott
    McKinney, Texas
    2012 Pyrite Mica 4X4
    Cooper Discoverer ATP tires, Bilstein 5100s all the way around, OME coils, Toytech AAL, debadged, removed pin stipe, chopped tail pipe, weather tech floor mats, Tonneau cover, Toyota bed mat, homemade eight ball gear shifter and cargo divider
    I have a YTS-23 Yamaha tenor sax that my parents got me back in 86 and I just found out that Yamaha used a clear baked epoxy lacquer on it. I would like to try to remove the rest of the epoxy so it can continue to tarnish. I've looked online and have found a couple of chemicals and/or solvents that could be used, but I was wondering in anyone had a better idea... Thanks
  2. Nov 14, 2012 at 11:42 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Media blasting
  3. Nov 15, 2012 at 6:43 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Methyl Ethyl Keytone or Xylene might work. Wear gloves and work outdoors. Both are very flammable and will strip your hands in short order.
    You're going to have to strip everything for this to look right. It's going to ruin your pads, and strip all of the lube from the pins and springs. A complete tear down and rebuild is what you're looking at, IMHO.
    The work would be worth it, if you're up to the challenge.
  4. Nov 19, 2012 at 7:12 AM
    skb7527
    Scott
    McKinney, Texas
    Thanks guys...I was hoping this could be done without having to completely disassemble the horn. Some of the laquer is coming off and I just want to "help" rest off....
