Removing Flares?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scosh, Jan 18, 2010.
  1. Jan 18, 2010 at 7:18 PM
    Scosh
    Scosh [OP] Well-Known Member
    Scotty
    New Iberia
    02 Prerunner SR5
    Bilstein 5100's all around, Limo Tinted windows, Moto Metal 951 wrapped in Revo 2's 265/70/16, clear corners, dual Magnaflow muffler, Turn signal mod, more to come...
    Ok so tomorrow I plan to paint my fender flares black and I wanted to know how hard is it to remove the flares? I tried pulling on it a little, but I didnt want to break anything. Any advice on removing them?
  2. Jan 18, 2010 at 7:22 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Fabtech Lift on top of 3 inch body lift. 34s trail grapplers on 18inch eagle alloys. KRFab Rear bumper, BHLM with HIDs, TRD seat covers, Hood scoop, N fab tire carrier, black valence, TRD intake, 40s Flowmasters, Foglight mod, best for last and thats my 4.56 gears, and much more too come.
    Well I switched out my fenders with some bushwackers. Idk if its the same for 1st and 2nd tacos but taking off the fenders were really easily. Just gotta pull hard and let them pop off gotta becareful tho since your gonna put them back on they clips in the back are a little fragile.
  3. Jan 19, 2010 at 4:26 AM
    Scosh
    Scotty
    New Iberia
    02 Prerunner SR5
    Ok thanks, Ill be sure to try taking them off after school today.
  4. Jan 19, 2010 at 5:02 AM
    Brunes
    Brunes abides.
    Rotorhead
    You can also just mask off the truck and paint them on there. Use a thin hard plastic to tuck between the flare and the body and then mask with tape and news paper. Paint away...and then pull all the mask when you are done.
  5. Jan 19, 2010 at 7:15 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    good luck!
  6. Jan 20, 2010 at 5:08 PM
    Scosh
    Scotty
    New Iberia
    02 Prerunner SR5
    I finished them, I would post pictures but its t-storming outside atm.
  7. Jan 20, 2010 at 5:16 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    How did you end up getting them off?
  8. Jan 20, 2010 at 6:20 PM
    Scosh
    Scotty
    New Iberia
    02 Prerunner SR5
    Well first I removed all of the bolts attached to the fenders. Then I took one end and pulled it back with enough force to pop out one of the little pins, and then I carefully pulled out each one and none of them broke. Then repeat the process for the others.
  9. Jan 20, 2010 at 6:27 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    There is actually a masking tape available that has a hard edge on one side made specifically for tucking it in behind a panel. I can't remember what it's called though. I saw it on a tv show. I can't recall which series but the episode was like "Second Chance Silverado" or something like that.
