Removing front brake lines
Discussion in '1st Gen. Tacomas (1995-2004)' started by copacetic1, Sep 4, 2015.
  1. Sep 4, 2015 at 2:01 PM
    copacetic1
    copacetic1 [OP] Don't get stuck on stupid.
    Colorado
    03 SR5 4X4 Dbl Cab
    Front: Bilstien 5100 / OME 880 Rear: Bilstein 5125 / Wheeler 5-leaf
    Installing new SS brake lines up front, any tips on removing connection for the stock rubber line to the the hard line? Very narrow fastener to get a wrench on and in a tight spot...image.jpg
  2. Sep 4, 2015 at 2:15 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Properly fitted tools - to prevent rounding the fittings. I'm not familiar with the 2nd gen components, but I've worked on many others. Spray the area with PB blaster or Kroil many times (or even days before) and let it soak.
    Just be careful and don't crank on it too hard...or you can twist the hard lines. Be patient... If things aren't budging - spray more and give it time. You'll be tempted to crank on it...resist the urge!
    I've had many situations where I've had to get the torch out.....not fun. GOOD LUCK!
  3. Sep 4, 2015 at 2:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What size is it? 10 mm? Probably have to use a brake line wrench like this.
    Rmodel65 likes this.
  4. Sep 5, 2015 at 6:11 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Yes GET ONE OF THESE! It is worth it even if you only use it for this job. If you strip the nut then you will have to buy a new hard line. I stripped mine but was able to put it back with vice grips, although I know I will have to replace it in the future.
  5. Sep 5, 2015 at 6:16 AM
    copacetic1
    Colorado
    03 SR5 4X4 Dbl Cab
    I've got line wrenches but the fitting is so rusted I'm afraid I'll just round it off. Access is really tight too, so I'm going to hold off for now. Thanks for the replies.
  6. Sep 5, 2015 at 11:55 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your doing brakes maintenance for the first time or it has been neglected .
    Here in the great rust belt I plan on just replacing the hard lines and keep them on hand
    Most times when new to me things are rusted so bad no matter how much Kroil is used it is not coming apart.
  7. Sep 5, 2015 at 8:26 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I have rounded more of those fittings with line wrenches then without. I would use either vice grips as tight as you can clamp them, or cut the rubber line off and use a socket if you are replacing those hoses.
  8. Sep 6, 2015 at 2:20 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I have to ask just how do you round flare nuts with a line wrench??
    Twist them off I can relate to
    Poor quality line wrench??
    By the time things are rusted that bad I would also be replacing the rubber lines as well.
  9. Sep 6, 2015 at 9:43 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
  10. Sep 6, 2015 at 10:24 AM
    Madjik_Man
    Colorado Front Range
    BDN, Viking Brett not myself could replace my front brake lines with the Wheelers steel braided ones because we couldn't get the rubber lines off.
    Keep me posted.
  11. Sep 6, 2015 at 6:25 PM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    I have done this more times than I can count, caliper bleeders seems to always do this even with a closed head wrench. I have a decent set of flare nut wrenches (craftsman) and when the nuts are rusty enough, the corners just crumble. I have been looking at new SS front brake lines, and I like the suggestion to cut the rubbers ones off and use a socket on the nut.
  12. Sep 6, 2015 at 6:29 PM
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    I had a set of line wrenchs from advance auto and they would ring off a bolt quickly. You could litterly see the wrench bend under pressure and spin around the nut. I recently done the brake line swap as well and bought new kolbat line wrench and the nut came right off. I'd spend a few days spraying them with pb blaster
  13. Sep 7, 2015 at 1:00 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Wow I use Snap On line wrenches twisted quite a lot off where the nut will turn in the fitting but not on the line
    Once the lines are off the first time the new ones get Never Seized
  14. Sep 7, 2015 at 7:42 AM
    slander
    Hickory, NC
    The ends of the line wrench just open up when pressure is applied. Granted my line wrenches are definitely on the cheap side.
  15. Sep 7, 2015 at 9:31 AM
    Janster
    Jandy
    Lancaster, PA
    First off....If the area is rusted bad enough, the rust deforms the shape of the nut. A flare wrench is best....but if the nut is deformed of its original shape - the wrench just rips the rusted/soft spots off and you have nothing left to work with.
    Compression fittings / flare nuts aren't made of titanium. The metal they're made of is obviously softer than the pressure of which you apply to them and can strip. You just have to know when to 'back off'.
    Before you actually round it.... think about taking a torch and heating the nut. This will help expand the metal / nut in hopes it'll separate from the threads and you'll be able to remove it while you still can put a wrench on it.
    Just BE CAREFUL with torching brake lines ( aka OILS) and have a fire extinguisher on hand. Make sure you have someone else at home when you do this....
    My husband and I have done this many times on our Jeeps.
  16. Sep 7, 2015 at 9:36 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^This. I used a flare wrench with great success when I changed mine. If you do use a torch, also be careful to not burn the fluid if you can help it. Obviously you'll be bleeding the brakes anyways, but still...
    Janster likes this.
  17. Sep 7, 2015 at 11:58 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Well Commonsense just looking at lines to rusted I don`t even bother just cut them off with Side Cutters
    Maybe that is why I never rounded any off
