Removing front driveshaft for drifting RWD with locker
Discussion in '3rd Gen. Tacomas (2016-2023)' started by howdat333, Dec 3, 2022.
  1. Dec 9, 2022 at 7:14 PM
    #61
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Slow and Steady: San Antonio drift?
  2. Dec 9, 2022 at 7:29 PM
    #62
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Skweezy Jibbs Racing School.
  3. Dec 9, 2022 at 8:11 PM
    #63
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Into a ditch or lamp pole
    blu92in99 and landphil[QUOTED] like this.
  4. Dec 9, 2022 at 8:19 PM
    #64
    landphil
    BC, Canada
    Tundra 5.7 mod
    Better than into a dumpster. Especially a:
    wilcam47 likes this.
  5. Dec 9, 2022 at 8:20 PM
    #65
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    tonered, dnlskier, wilcam47 and 2 others like this.
  6. Dec 9, 2022 at 8:38 PM
    #66
    lbhsbz
    lbhsbz Well-Known Member
    Why can't it be both?
    wilcam47 and Cpl. Punishment like this.
  7. Dec 10, 2022 at 2:55 AM
    #67
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    That was the worst drift in the history of shitty drifts. Congratulations op!
  8. Dec 10, 2022 at 5:40 PM
    #68
    howdat333
    howdat333 [OP] Member
    dank
    jdm taco
    2021 V6 Manual
    thats why i need the 2wd locking diff bros
    gonna take the front shaft off and report my findings in the tacomaworld scientific journal for peer review
    FLAK-TAC likes this.
  9. Dec 11, 2022 at 11:27 PM
    #69
    howdat333
    dank
    jdm taco
    2021 V6 Manual
    B9F5F694-9434-4714-8C5A-135267D471AF.jpg 34552E0A-1E89-4E60-AD55-88C723DE24A5.jpg 00C33E10-B5BF-481E-BAE7-0D631CC477E2.jpg BB268054-F23E-4FD3-9C91-E4B8EBC02FDE.jpg 4611261D-5A9C-4A3A-B350-B825034B46B0.jpg 52DAE201-0B05-4777-8ED6-0443A3839BDC.jpg 4611261D-5A9C-4A3A-B350-B825034B46B0.jpg BB268054-F23E-4FD3-9C91-E4B8EBC02FDE.jpg 00C33E10-B5BF-481E-BAE7-0D631CC477E2.jpg took it off
    truck does go into 4hi 4lo and 4lo diff lock, both rear are confirmed locked and tires spinning super slow like double slow not sure this gonna be streetable or driftable but if i her stuck with no 4wd the locked 2wd with low-low gears ought to get me out the ditch lol.
    did find out fox shock BROKE at top mount. how?
    also, bot a fancy bluetooth obd2 scanner to clear tss but o error code. anyone got latest thread ok resetting tss after lift? i unplugged neg batt cable overnight, will see if it resets tss
    now looking for chepaest stiffest rear shock for taco. which is it? rough country, fabtech?
    why cant we just have 2hi lockers smh
    B9F5F694-9434-4714-8C5A-135267D471AF.jpg B9F5F694-9434-4714-8C5A-135267D471AF.jpg 34552E0A-1E89-4E60-AD55-88C723DE24A5.jpg
  10. Dec 11, 2022 at 11:31 PM
    #70
    TireFire
    Olympic Peninsula
    You’re not going to need a new shock, it just limits travel :)
    tinker_troy likes this.
  11. Dec 11, 2022 at 11:48 PM
    #71
    MGMDesertTaco
    Not the first time I've seen those fox 2.0's break there. Why did you remove the driveshaft? :confused:
    auskip07 likes this.
  12. Dec 11, 2022 at 11:48 PM
    #72
    howdat333
    dank
    jdm taco
    2021 V6 Manual
    Just let er bounce with no shocks, like no sways either? Hoods coming off next
  13. Dec 11, 2022 at 11:50 PM
    #73
    howdat333
    dank
    jdm taco
    2021 V6 Manual
    To try and drift in 2wd locked but the gearng is super super low. Any way to lock in regular ratios?
  14. Dec 11, 2022 at 11:51 PM
    #74
    MGMDesertTaco
    Rear diff lock is for 5mph or less. Do as you wish. It's your truck.
    G2.M6 and auskip07 like this.
  15. Dec 11, 2022 at 11:55 PM
    #75
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  16. Dec 12, 2022 at 12:07 AM
    #76
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    weld it
    Too many electronics in the 3rd gens.
    honest opinion: buy a 1st Gen prerunner with a rear locker, gray wire mod it and bango. You got everything you need
    soundman98 and Cpl. Punishment like this.
  17. Dec 12, 2022 at 12:08 AM
    #77
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Wth is this dumpster fire
  18. Dec 12, 2022 at 12:08 AM
    #78
    MGMDesertTaco
    TnShooter likes this.
  19. Dec 12, 2022 at 12:15 AM
    #79
    TnShooter
    Deogee
    STOCK
    I mean, if you are set on doing it. And you’ve already pulled the front driveshaft.
    What would happen if you locked the diff in 4LO.
    Unplugged the diff lock connector on the rear diff.
    Then switched back to 4Hi with the diff lock connector unplugged?
    Of course, you should do this at your own risk.
    I have no idea what what will happen.
    And I’m more less here to see how much abuse the stock locker will take before it breaks.
    Basically, what I’m saying is, I’m here for the carnage.
    But props to you for trying. I guess:confused:
  20. Dec 12, 2022 at 12:45 AM
    #80
    TireFire
    Olympic Peninsula
    It will unlock if you unplug it. It’s an electro magnetic design.
