Removing grille clips
Discussion in '1st Gen. Tacomas (1995-2004)' started by pofarm, Jan 5, 2016.
  1. Jan 5, 2016 at 1:45 AM
    pofarm
    pofarm [OP] Well-Known Member
    Greg
    SW MO
    1996 Taco
    I need to remove the grille on my 96 Taco. Someone removed it in the past and broke some of the clips. Thought I would ask what is the best way to release the clips so I don't break them. Thanks.
  2. Jan 5, 2016 at 2:34 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    If the clips look like this:
    Take a small screwdriver and depress the center peg in either direction. You dont need to bend it much for it to release.
    pofarm[OP] likes this.
  3. Jan 5, 2016 at 2:37 AM
    pofarm
    Greg
    SW MO
    1996 Taco
    That's what they look like. Thanks for the reply.
  4. Jan 5, 2016 at 4:57 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
  5. Jan 5, 2016 at 12:02 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    My technique is to use a very long flathead to push down on the clips, while simultaneously gently pulling the grille. Do each one at a time, first the lower/upper clip and then the one vertically adjacent. I usually start with the center, pull out that section first, then go to the left or right side and pull out that section and then the last. Essentially you want to get the clip "unseated" enough so that you can loosen each section at a time and eventually pull the whole grille out.
    This may only apply to 01-04s, but:
    There may also be a couple of lower clips on the bottom left and right corners, just reach up under the front bumper, feel around for the clips behind the headlight fillers (it's like a U shape clipped into an I shape, you want to separate the "U" clip on the grille from the "I" clip on the headlight assembly to pop it out) and pop those out too, those are the last step, both for removal and reinstallation.
    _chris and pofarm[OP] like this.
  6. Jan 5, 2016 at 12:59 PM
    pofarm
    Greg
    SW MO
    1996 Taco
    Thanks for the replies. I will get some clips ordered, since some are already gone. I'm going to be replacing the anemic horn with twin horns.
  7. Jan 6, 2016 at 4:33 AM
    NM Lance
    NM Lance Well-Known Member
    ^This. I broke nearly all of mine before figuring out how the goofy things worked.
  8. Jan 6, 2016 at 4:54 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Take a chunk of change with you... Toyota is really proud of these clips.
  9. Jan 6, 2016 at 4:58 AM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    I finally just ordered a bag on eBay for cheap and keep them on hand for whenever I have to take the grill off. I find it easier to replace them than to kill myself for 15 minutes getting one dang clip out.
    KdF[QUOTED] likes this.
  10. Jan 6, 2016 at 11:29 AM
    pofarm
    Greg
    SW MO
    1996 Taco
    I'm not going to grace the stealer's door. I will get them off ebay.
  11. Mar 20, 2016 at 10:38 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    I've got a few of these broken on mine too. How much did you end up paying for them?
