Removing leaf from Dakars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, Dec 19, 2017.
  1. Feb 12, 2020 at 8:49 PM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Old ass thread but how did you determine the right size for the new centering pin? Looking to remove the upper overload as well but don't want to rip it apart to find out I got the wrong size bolt to use as the new centering pin...
    That is if what I read about the OME centering pin not being fully threaded was true
  2. Feb 12, 2020 at 8:55 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I didn't need a new centering pin - just re-used the old/original one. No problems, to date. As with most things, YMMV. Good luck!
  3. Oct 4, 2021 at 12:00 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    About to remove the 3rd leaf this weekend. Between that and going from e to c load tires, hopefully the ride gets a lot more comfortable
  4. Oct 9, 2021 at 8:18 PM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    I'm running the EL095R pack with the big overload spring removed, netting me a 4+1 spring setup. It's perfect with Timbren Active Off-road bumps. Truck hauls and tows soo much better. With my TRD Baja (Pro) suspension it nets me about an inch of rake and is perfect. For a stock truck I do believe you can remove the middle leaf as well.
    scootter82 likes this.
  5. Nov 6, 2021 at 7:55 AM
    scootter82
    Aurora, CO
    Ride is so much better with the 3rd leaf removed, and c load tires! But now I gotta readjust the front king coilovers down a tad.
  6. Aug 1, 2022 at 3:26 PM
    tgibello
    tgibello Member
    Tyler
    1998 Tacoma 4WD
    Does anyone know if the removing of the 3rd leaf and the larger overload holds true for the 1st gen packs?
