Removing leafs from Deaver U402
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikalcarbine, Nov 26, 2023.
  1. Nov 26, 2023 at 1:27 PM
    mikalcarbine
    mikalcarbine [OP] Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    I have a U402 Stage 1 leaf spring kit on my Taco. It's netted about 1.6-1.75" of rake in the rear and is a bit on the stiff side. I called Deaver and they said removing the 5th leaf from the top should lower my height by about an inch which I think is a tad too much. They said either overload could be removed as well.
    Has anyone had any experience with removing leafs from their U402 kits? I'm looking to soften up the ride a bit and lose about 1/2". The overloads are about 5/16" which may be good enough but I don't know if it will really soften up the ride quality.
    I have a camper shell but other than that my bed is empty 99% of the time except for a dozen or so camping trips a year.
    GilbertOz likes this.
  2. Nov 26, 2023 at 1:42 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Time to experiment. Pull a leaf and see how it is. If you don't like it put it back rinse and repeat.
  3. Nov 26, 2023 at 2:15 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I would be adding weight to get to the desired/acceptable ride and see what that takes and perhaps that would be your best option so you don't end up in the opposite scenario when you go camping and being under sprung. Even if it was just adding sandbags. The other option would be to go soft on the springs and add air bags for when you load it up. But sandbags are cheap and easy.
    wi_taco likes this.
  4. Nov 26, 2023 at 2:34 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    ^ This. I have the U402 state II and carry more weight than OP on a daily basis. Ride quality was always good for me but that could be due to the extra weight. Mine sat very tall at the start but settled and dropped 0.25-0.5" in the end. I'd leave all the leaves in and load up on sandbags to simulate your camping loadout and let them wear themselves in.
  5. Nov 26, 2023 at 7:31 PM
    mikalcarbine
    Phoenix, AZ
    2015 AC TRD OR
    Thanks guys I'll do some playing around I just wanted to see if anyone had any experience with removing any leafs. These are a few years old and are definitely broken in now and I've had the camper shell for about a year. I agree I don't want to be under sprung when I do load up.
