removing leafs
Discussion in 'Suspension' started by lpd1214, Dec 31, 2007.
  1. Dec 31, 2007 at 1:31 PM
    lpd1214
    lpd1214 [OP] Member
    San Diego CA
    05' Silver Tacoma
    Flowmaster exhaust, billet grille, 5% tint back window
    i have 3 inch blocks on the back but its not low enough for me and i cant afford bags, so i was wondering hoe to remove a leaf from the leaf springs because i have never done it before
  2. Dec 31, 2007 at 1:34 PM
    lpd1214
    lpd1214 [OP] Member
    San Diego CA
    05' Silver Tacoma
    i have an 05' standard cab with 3'' blocks on the back, but its not low enough for me. i cant afford to bag it so i was wondering how to remove a leaf from the leaf springs because i have never done it before, or if you have any other ideas
  3. Dec 31, 2007 at 2:17 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the mods might move this to the second gen section, but are i take it ur running a 5 lugger?
  4. Dec 31, 2007 at 4:03 PM
    lpd1214
    lpd1214 [OP] Member
    San Diego CA
    05' Silver Tacoma
    ya its a 5 lug
  5. Jan 1, 2008 at 10:59 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    removing one leaf is easy and kinda dangerous...i do that type of stuff al the time.....
    1.jack veh up remove tires put on jack stands on frame not axle let axle hang
    2.place floor jack under axle on one side to support it.
    3.remove the ubolts and possibly the shock (just unbolt the lower end)
    4.use jack to allow axle to drop away from spring pack.
    5. place two good c-clamps on the spring near the center bolt.
    6.slowly using hand tools (no impact guns) remove center bolt from pack.
    7.slowly undo c-clamps evenly so one isnt farther apart then other till the pack is loose.
    8. pull out the leaf you want, (i suggest not the bottom one but next up)
    9.place clamps back on pack minus one leaf...push bolt through, use clamps to pull the pack back together till you can get nut on center bolt then use combination of clamps and tightening the center bolt till the pack is back together..
    10. re-assemble that side and move to other..repeat process..
    having the axle hanging and using the jack to lower it out of way is important but you also want to watch that you dont let it go to far hurting brake lines!
  6. Jan 2, 2008 at 1:42 PM
    lpd1214
    lpd1214 [OP] Member
    San Diego CA
    05' Silver Tacoma
    thanks a lot that is easier than i thought that it would be
