Removing lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scottyballz, Feb 10, 2018.
  1. Feb 10, 2018 at 12:19 PM
    scottyballz
    scottyballz [OP] Member
    2015 Tacoma TRD Sport
    hey guys, I’m removing the 3” pro comp lift on my 15 trd sport crew cab. I’m gonna take it back to stock with OEM coil springs and some bilstein 5100’s. I found a pair of OEM coil springs from a 13 trd off road access cab. Just want to make sure these will fit. Thanks guys.
  2. Feb 10, 2018 at 12:23 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Ya they fit, not sure if double got different spring rate over access though
    11Bguy likes this.
  3. Feb 10, 2018 at 12:30 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Off Road springs are different than Sport springs but they should work fine
  4. Feb 10, 2018 at 3:06 PM
    scottyballz
    How about the stock u bolts from that same truck. They are the same correct?
  5. Feb 10, 2018 at 3:08 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yes
  6. Feb 10, 2018 at 3:09 PM
    scottyballz
    I’m
    awesome! Thanks for your help guys
  7. Feb 10, 2018 at 3:24 PM
    Pigpen
    Dan
    Northwest Montana
    Easy there
  8. Feb 10, 2018 at 4:15 PM
    scottyballz
    Haha, no idea where the “I’m” came from. Anyway, thanks again guys!
    Pigpen[QUOTED] likes this.
