Removing lower oil pan (for gasket replacement)
Discussion in '1st Gen. Tacomas (1995-2004)' started by AllyYoda, Apr 13, 2019.
  1. Apr 13, 2019 at 11:06 AM
    AllyYoda
    AllyYoda [OP] Member
    Atlas
    1998 Toyota Tacoma 4x4
    Hello everyone!
    Atlas and Lady Bits here -
    Got myself a nasty leak along what looks like a terrible attempted seal by the previous owner. I have all my bits and pieces and am ready to do the job, but upon getting under my truck I’m wondering how to weasel the oil pan out from behind the front diff?
    Any guidance is appreciated!
    CS_AR likes this.
  2. Apr 13, 2019 at 1:28 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    I had to replace the pan on mine two years ago and unfortunately, you have to remove the front differential to remove the oil pan :/
    CS_AR likes this.
  3. Apr 13, 2019 at 1:45 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    ^^^ This definitely for a 4x4.
  4. Apr 13, 2019 at 3:35 PM
    tony2018
    tony2018 Well-Known Member
    oil pan uses FIPG, there is no rubber gasket.
  5. Apr 13, 2019 at 3:46 PM
    CS_AR
    I use a thin blade putty knife with a metal head (absorbs shock from a hammer) to drive in between the oil pan and the block to cut an oil pan loose. Also, don't drive it in past the rim on the oil pan.
