Removing M4 Handguard
Discussion in 'Guns & Hunting' started by Rivet Joint, Feb 3, 2011.
  1. Feb 3, 2011 at 10:34 AM
    Rivet Joint
    Rivet Joint [OP] Well-Known Member
    Albuquerque, NM
    2010 SWB DC Sport
    5100s @ .85, OME 885s, Rear TSB, Helo Max 6's, General AT2 Tires, Black Badges, Demello Offroad Bumper, Grillcraft, Sub/Amp, Pioneer DVD HU, TRD Intake & Exhaust.
    I have a Bushmaster with a handguard like this one. Are there any tips or tricks out there to remove the handguard? I know there is a tool for it but I would rather not buy it if I am going to use it once. I'm looking to replace the old handguard with a quadrail. Thanks!
    I'm looking at getting this one...more or less...
  2. Feb 3, 2011 at 10:37 AM
    Ralph Pootawn
    Ralph Pootawn Well-Known Member
    Fairfax, Va
    '11 Timberland Mica TRD Off-Road
    N/A
    See that tapered ring directly behind the handguard? I think it's called the delta ring? You can pull it back and expose the "lips" that hold the handguard in place. pull it back and the handguard will fall into 2 pieces.
  3. Feb 3, 2011 at 10:38 AM
    Ralph Pootawn
    Fairfax, Va
    N/A
    The one you want id a free-float handguard and will require the removal or the front sights to get the hardware on.
  4. Feb 3, 2011 at 10:39 AM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Albuqerque
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    if its a newer gun it will prolly be tough and it will prolly take a few tries
  5. Feb 3, 2011 at 10:40 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    I dont know about yours but the ones we used in the military you just pulled down on the cone shaped thing near your lower reciever and carrying handle. You should be able to just pop one side off at a time. It might take a lil elbow grease.
  6. Feb 3, 2011 at 10:43 AM
    Rivet Joint
    Albuquerque, NM
    2010 SWB DC Sport
    Sweet...I got it. That was easier than I thought.
    Ralph Pootawn...Thanks for the heads up!
  7. Feb 3, 2011 at 10:45 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    yea. It takes some strength. I use a delta ring tool for mine.
  8. Feb 4, 2011 at 3:34 AM
    Ralph Pootawn
    Fairfax, Va
    N/A
    No prollum, just post pics once you get the new one!
