Removing Map Light Cover
Discussion in '1st Gen. Tacomas (1995-2004)' started by Seagull233, Jun 9, 2017.
  1. Mar 8, 2018 at 5:49 AM
    ThatRedYota
    ThatRedYota Well-Known Member
    Nikola
    2003 Red Prerunner TRD Offroad
    Fox 2.5 IFP Coilovers, BTF uniball UCA's 295/75/r16 Toyo AT2s, front tube bumper (custom), rear tube bumper (custom), radiator guard, Assault light bar, Stereo, 3D printed Offroad switch panel/ mount
  2. Mar 8, 2018 at 11:50 PM
    djohn24
    djohn24 Well-Known Member
    Dennis
    Pa
    03 Double cab SR5 Tacoma 4x4
    Not 100% sure but i would say yes. Since installing the LED lights, at first having dome and map lights on. When I would turn off map lights it would turn off dome light too in the door position. Not doing it now.
    QMEDJoe[QUOTED] likes this.
  3. Mar 9, 2018 at 12:37 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Ok, so that confirms to me their wired in together. Thank you sir!
  4. Oct 31, 2018 at 5:34 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Is there any fix for LEDS to have them turn when the door is open when the map light is on the door position?
  5. Oct 31, 2018 at 7:06 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Yes if you run the 2nd gen T4R map light & run an additional wire for the door jamb switch. Bolts right on & looks the same except the 2nd gen T4R map light has an additional switch for this labeled door. I have one, too lazy to go take a pic.
    Also if you care, depending on the color of your interior you may have to paint the map light cover as the T4R interior colors do not match Tacomas, the gray doesn't anyway, not sure about the tan.
