Removing mini fuses
Discussion in '4th Gen. Tacomas (2024+)' started by jd4858radar, Nov 22, 2024.
  1. Nov 22, 2024 at 12:28 AM
    jd4858radar
    jd4858radar [OP] Member
    2024 Underground Tacoma
    Has anyone tried to remove any of the mini fuses from under the dash? Does the tool in the fuse box by the engine work, or would they suggest a better tool. Not interested in using something like needle nose pliers.
    Going to have to remove the one that supplies power to the 12v socket. Currently have a plug in the 12v socket that is stuck and cannot remove.
    Thanks
  2. Nov 22, 2024 at 5:35 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    yes special tool is EL-3922-j/needlenose......
  3. Nov 22, 2024 at 5:55 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    I only use Snap-On needles nose...:frusty::rolleyes:
    wilcam47 likes this.
  4. Nov 22, 2024 at 6:00 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yep. A needle nose...is what I use.
    SR-71A likes this.
  5. Nov 22, 2024 at 6:20 AM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    OP, did a set of needle nose molest you or something?
  6. Nov 22, 2024 at 7:36 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    You can get pliers for electrical made of plastic if the metal is what concerns you.
    I’ve always kept a pair of needle nose in the truck for the fuses. Never had an issue.
  7. Nov 22, 2024 at 8:45 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    I've removed one. The tool does work, just make sure you seat it fully on the fuse and pull from the sides so you don't open it back up.
  8. Nov 22, 2024 at 9:12 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    JB_TN[QUOTED] and BluberryBCtaco like this.
