Removing motor oil from garage floor
Discussion in 'Garage / Workshop' started by Bagman, Mar 13, 2014.
  1. Mar 13, 2014 at 7:14 PM
    Bagman
    Bagman [OP] Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    My son just bought a house where the previous owner's car must have leaked oil onto the garage floor for years. Looking for product recommendations for removing said oil stain from the floor. I'd like to get it clean enough to then do a floor coating of some type. Suggestions appreciated.
  2. Mar 13, 2014 at 7:18 PM
    jro1
    jro1 Well-Known Member
    jesse
    Red Deer AB, Canada
    2011 Tacoma TRD sport
    Driver
    Gasoline, scrub brush, and elbow grease!
  3. Mar 13, 2014 at 7:33 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
  4. Mar 13, 2014 at 7:49 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    try liquid dish soap... put it over the stains and let it sit for a day... you can try agitating it a little w/ a brush, ...use the soap liberally... try rinsing it off after a day or so, ...it should help diminish the stain ;)
  5. Mar 13, 2014 at 7:56 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Tide, believe it or not.
  6. Mar 13, 2014 at 8:03 PM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
  7. Mar 13, 2014 at 9:13 PM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    Hot soapy water through a pressure washer
  8. Mar 13, 2014 at 9:21 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    1 to 3 mixed simple green and hot water. That's how we mop oil spills in the machine shop I work.
  9. Mar 14, 2014 at 6:44 AM
    Bagman
    Area 51
    Thanks for all the suggestions guys. I'll start with the Simple Green since I have a gallon on the shelf.
  10. Mar 14, 2014 at 6:50 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Simple green 50/50 heated is what I use works well too, and of course a stout brush and elbow grease as previously mentioned.
  11. Mar 14, 2014 at 6:52 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Carb cleaner and a brush or mean green/simple green and a brush (what i use at the house garage). I used to have some industrial floor cleaner from cleaning a tire shop but i don't remember the name of it.
  12. Mar 14, 2014 at 6:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd figure out what kind of coating you plan on putting on the floor as they may specify what type of floor cleaning and prep would be required. I'd use as little water as possible, concrete absorbs water and can cause problems for future floor coverings. Try just putting down kitty litter, grind it in with your foot and use a heat gun on the slab in that area. Keep grinding the kitty littler in with your foot every so often as you heat it then sweep the kitty litter away.
  13. Apr 20, 2014 at 5:35 AM
    Executive
    Executive Conservative
    Peabody, Massachusetts
    2012 DCLB TRD Sport
    Mix a box of baking soda with the Simple Green into a paste. Scrub the paste into the stain and let it stay there for a few days. Rinse and repeat.
    Whatever the Simple Green does not emulsify, the baking soda will absorb.
  14. Apr 20, 2014 at 5:48 AM
    Tacoma VT
    Tacoma VT Well-Known Member
    R. Kessler
    Vermont
    10 DCLB TRD sport
    OME 884s, Bilstein 5100 Shocks, Icon 3 leaf progressive AAL (with overload in), Rear leaf TSB, ImMrYo mirror relocater, ARE Z series cap, Hi Lift jack W/ DIY mount, trimmed Mud Flaps, Devil Horns by Andres, EGR In-Channel rain guards, LED bed lights, Weather Techs
    When I drip some on the floor, I grind mulch into the spot and leave it over night. Sweep it up and the stain is gone.
  15. Apr 20, 2014 at 6:08 AM
    Bagman
    Area 51
    Thanks again guys. Went with warmed up Simple Green and mixed it with an oil absorbent product I had access to. Let it sit most of the day and scrubbed with a stiff brush. Most of it came up. Going to do a second application to see it I can get it all this time.
