Removing Mudflaps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jflan, Jul 26, 2009.
  1. Jul 26, 2009 at 5:27 PM
    jflan
    jflan [OP] Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I want to remove my front mudflaps and see that there are 3 bolts and three plastic rivets on each.
    I tried to pry out one of the rivets and snapped the top of the rivet off.
    Is there a way to save the rivets (and get the flaps off) or do they have to be destoyed (drilled out) ?
  2. Jul 26, 2009 at 5:32 PM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denver
    '09 4X4 TRD Off-Road
    Lifted and bigger tires
    i just un-bolted the three nuts, and pulled the flaps off. One of the plastic rivets broke on the first flap, but the second one they all came off easily. just yank. and if you want a little extra help get a flat head screwdriver and wedge it under the head of the rivet and pry it off while you yank on it.
  3. Jul 26, 2009 at 5:34 PM
    fghtngsquirrel
    fghtngsquirrel Ka-freakin'-BOOM!
    Jacksonville, FL
    '08 4x2 Rad Red *SOLD*
    I broke a couple as well, but my local dealership gave me replacements for free (didn't like the holes). Good luck!
  4. Jul 26, 2009 at 5:35 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    On the first one, I used a screwdriver on each side of it and pryed up (2 screwdrivers).
    I broke 1 of the 3 rivets (tore the head off).
    On the second one, I removed the bolts and just grabbed the flap and pulled toward the front of the truck. They all just popped right out.
  5. Jul 26, 2009 at 5:47 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    was just looking at other site about these
    part number 90467-07188
    listed at $1.14
    even if only a couple bucks, worth picking up extras
  6. Jul 26, 2009 at 6:26 PM
    jflan
    Vancouver, WA
    Cool.
    Thanks guys :)
  7. Jul 26, 2009 at 7:31 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    the plastic pop rivets are two pieces. Take a flat screw driver and you pry between the two pieces. You are basically separating two pieces. Once removed I would suggest either leaving them out or buying some of those generic plastic retainers that look like the stock ones. Once you take off the mudflaps and remove the rivets there is a lack of thickness so the rivets are loose and will probably fall out. I just pulled off my mudflaps today.
