Removing O2 sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thadri, Feb 10, 2018.
  1. Feb 10, 2018 at 1:58 PM
    thadri
    thadri [OP] New Member
    2008 Tacoma 2wd
    Hi everyone!
    I have a few questions regarding the repair of a Bank 1 sensor 1 O2 sensor on a 2wd 2008 Tacoma.
    1) is the one just before the cat underneath the truck near the right front tire area the right one or is bank 1 sensor 1 further upstream?
    2) any tips on a rusty removal? Been spraying with PB blaster and rented an O2 socket so I don't have to cut the wire and I can still drive the truck.
    Thanks in advanced!!!
  2. Feb 10, 2018 at 2:01 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    I have one of these and love it. Used it on my wife’s trailblazer with 180k miles and the O2 sensor came right off.
  3. Feb 10, 2018 at 2:07 PM
    thadri
    2008 Tacoma 2wd
    Yes I rented this set from autozone with a piece just like this, still having trouble. Thanks for your reply!!
  4. Feb 10, 2018 at 2:11 PM
    thadri
    2008 Tacoma 2wd
    I have 90 days with it and can take my time and try different strategies, truck still runs fine. Right now I just plan to spray with PB blaster often and keep trying, maybe with truck hot from driving next time. Does anyone know if I am yanking on the right sensor? You can see it pretty easily under the right front tire area...
  5. Feb 10, 2018 at 2:22 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Try a 50/50 mix of acetone and ATF fluid. instead of the pb
  6. Feb 10, 2018 at 2:54 PM
    thadri
    2008 Tacoma 2wd
    I've read about this, will it damage the housing into the exhaust?? Thanks for your reply!!
  7. Feb 10, 2018 at 5:36 PM
    Kotah
    Kotah Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    Get you a cheater pipe and put on the end of your wrench to give you more leverage
    Hunter.415 and crashnburn80 like this.
  8. Feb 10, 2018 at 8:01 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I would spray it with PB than drive it to get it hot, than spray it with PB again....if it's really the bad, you could always use kroil and a torch.
  9. Feb 12, 2018 at 12:40 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Your best bet is going to be mechanical leverage. Either use a pipe over the end of your wrench or pick up a real breaker bar:
    Hunter.415 likes this.
  10. Feb 12, 2018 at 5:00 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I used a box wrench. The connector for through and it didn't open up like there sensor socket did.
  11. Feb 12, 2018 at 10:30 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    For really stubborn o2 sensors, spray with pb blaster, rattle the surrounding area with an air hammer with a flat bit lightly, cut the harness and slip over a 22mm wrench and bust it out of there. Sometimes if they are seized you can take the threads out of the bung and you will have to have a new bung welded on.
  12. Feb 12, 2018 at 10:34 AM
    Larzzzz
    Larry
    MA
    That would seriously suck.
    I always tighten first. I just want to see it move before i loosen anything that i think is gonna give me grief
    Bebop likes this.
