Removing OEM Roof Rack Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fullsendcf, Apr 8, 2021.
  1. Apr 8, 2021 at 10:57 AM
    Fullsendcf
    Fullsendcf [OP] Well-Known Member
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Hey TW - going to be removing my OEM roof rack as I’ve finally got my hands on some replacement weatherstrips.
    Had some questions before doing so.
    As I plan to add an aftermarket roof rack in the future I wanted to see what the best option would be:
    1. Cover the holes with mastic tape and apply silicone to seal, then mount weatherstripping
    2. Find shorter replacement bolts (since OEM bolts are longer) and mount with blue loctice, mastic tape, then mount weatherstripping
    Done a lot of research on TW and elsewhere with no conclusive results. Appreciate the help in advance!
  2. Apr 8, 2021 at 11:00 AM
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    Personally I’d do option one on the off chance the bolts get stuck in there.
  3. Apr 8, 2021 at 11:05 AM
    Bdbakel
    Bdbakel Well-Known Member
    Illinois
    '19 Sport DCSB 4X4 6MT Barcelona Red
    Curious as to why you're replacing it with the weather stripping if you want an aftermarket rack in the future. Just not a fan?
    I would probably to with #1 as well.
  4. Apr 8, 2021 at 11:11 AM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    If you want to go to an aftermarket rack, I would just wait until you have the aftermarket one to take the OEM off.
    Not really a point in adding a risk of leak when you don't have to.
  5. Apr 8, 2021 at 11:22 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    The OEM 'seal' is a sticker.. so anything above that is good.
    When I traded in my 2005 I used a dab of silicone and a flap of duct tape.
    Fullsendcf[OP] likes this.
  6. Apr 8, 2021 at 11:26 AM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Yep. I was going to mount something on mine and removed the sticker. Ended up not doing it and threw a strip of e-tape over it.
  7. Apr 8, 2021 at 3:10 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    It's sad you have to specify that you've already done research and people can't just be happy enough to assist you without that.
  8. Apr 8, 2021 at 3:38 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    just understand, that dust, debris have already got between the weatherstrip, rack and truck's finish, and there will be some deeper marks that may not be able to be removed with normal paint correction methods. I bought my truck new in november of 19, within days, I removed my factory rack, replaced with the factory weatherstrips... both sides on the roof where the rack was, had significant marks in the finish. It doesnt completely penetrate the clear coat so, I chalk it up to, the only time I see it is when I was, dry, or apply a finish protectant to the roof.
    you will need the 2 rear corner pieces, the 2 weatherstrips, and 4 retainer clips that are glued to the roof, to retain the front and rear of the weatherstrip to the roof. no need to install screws or bolts. fill the holes with sealant like silicone, or windshield urethane, and or place some tape over the holes, prior to installing the weatherstrips. Ski
    vicali and Fullsendcf[OP] like this.
  9. Apr 8, 2021 at 3:51 PM
    Fullsendcf
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Appreciate the insight! Are those retainer clips necessary? I’ve seen some folks just o the silicone + tape or even just tape.
  10. Apr 8, 2021 at 4:47 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Too many questions about tire size. Haha this is an unusual question and I'm happy to give my anecdotal experience.
  11. Apr 8, 2021 at 5:03 PM
    kas2828
    kas2828 Well-Known Member
    Austin
    Arizona
    2020 TRD Off-road 4x4 DCLB
    What's your plan for the OEM roof rack? Selling?
  12. Apr 8, 2021 at 5:08 PM
    RedWings44
    Michigan
    I can understand that. Posting a link helps. But some people don't want to read through hundreds of pages of discussion. I admire the way @crashnburn80 runs his pages and never shys away from helping people with their questions or directing them where to go.
  13. Apr 8, 2021 at 5:10 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Nothing but respect for Crashnburn and all his contributions. Great example.
  14. Apr 8, 2021 at 5:33 PM
    Fullsendcf
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Well new hurdle... just tried to remove the rack and the bolts are on there tight as hell. Ended up stripping a few of them. Oh well, will call my local shop to see if they can assist :sadviolin:
  15. Apr 8, 2021 at 6:44 PM
    skidooboy
    central lower mich
    they are on there from the factory to help hold the front and rear down. they come off easily with them on there. they will come off even faster without them, in my opinion. I installed mine, for my peace of mind. Ski
  16. Jun 11, 2021 at 6:33 PM
    coreyreibsome
    coreyreibsome Member
    Corey
    2019 TRD Off-road 4x4 DCSB Cement gray
    The truck I just got has a OEM roof rack as well and I absolutely hate it. Curious as to if you removed yours already and how it went
  17. Jun 11, 2021 at 6:35 PM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Where are you located
  18. Jun 11, 2021 at 6:36 PM
    coreyreibsome
    Corey
    Pennsylvania
  19. Jun 11, 2021 at 6:37 PM
    mysubiewasalemon
    Okay was going to offer to swap moldingns with you
