removing oil pan
Discussion in '1st Gen. Tacomas (1995-2004)' started by da0023, Feb 28, 2010.
  1. Feb 28, 2010 at 5:10 PM
    da0023
    da0023 [OP] The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    Hey guys I need some assitance. I am in the process of removing my oil pan to replace the gasket because it has developed a bad leak. I have the skid plates removed as well as all of the bolts that hold it in place. I am having troubing getting the pan removed from the engine, it seems that old gasket has got a firm hold on it. I have heard nasty rumors that the lip on the pan can be easily warped if not removed with care. What is the best way to remove it without damaging it? thanks in advanced.
  2. Feb 28, 2010 at 5:21 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    once you are sure you have ALL bolts removed, take a razor blade and slide it in the crevice and cut the old gasket, just an idea
  3. Feb 28, 2010 at 5:43 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    drop an m-80 in the pan......just kiddin.try to drive a putty knife or large pry bar in the gasket with a hammer sometimes works the best for me.
  4. Mar 1, 2010 at 3:00 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    bump....anymore suggestions?
  5. Mar 1, 2010 at 3:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    not sure how exactly the pan on the 4cyl looks/where its at....but usually, remove all the bolts and use a flat blade screwdriver or a small prybar to break it loose, then pull it off....clean it out, replace gasket and bolt back up.
  6. Mar 1, 2010 at 3:49 PM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    X2 use both a flathead and small prybar(or what you got thats similar) at the same time as close to the corners as you you to help avoid warping the pan. i you have to, lightly tap the tools in between the pan and block with a hammer then pry. just use care and work it slowly, youll get it:).
  7. Mar 2, 2010 at 2:57 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    thanks for all the great tips guys. when the weather warms back up, i will give it a try.
