Removing or replacing shark fin antenna
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joeyf1986, Aug 16, 2018.
  1. Aug 16, 2018 at 9:54 PM
    Joeyf1986
    Joeyf1986 [OP] Well-Known Member
    I have a front runner rack roof rack with slide out table, which I can't use because the sharkfin antenna gets in the way of inserting/removing the table.
    I don't want to slide the table from the front because I have a wind damper.
    Does anyone know of a slim antenna that will work and seal against the elements? Or even a delete for the antenna that does not look too horrible?
  2. Aug 17, 2018 at 1:09 PM
    Joeyf1986
    Nobody has run into the issue?
  3. Aug 17, 2018 at 1:21 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  4. Aug 17, 2018 at 3:56 PM
    ELT2JV
    ELT2JV Well-Known Member
    17 TRD OR ACLB
    8112 front 8100 rear. Method NV with 265/75/16 KO2.
    Panchito V, Malvolio, JaxUmp and 3 others like this.
  5. Aug 17, 2018 at 4:03 PM
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
  6. Aug 17, 2018 at 4:06 PM
    ELT2JV
    17 TRD OR ACLB
  7. Aug 17, 2018 at 4:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Search "antenna"?
    Malvolio, ELT2JV[QUOTED] and hiPSI like this.
  8. Aug 17, 2018 at 6:57 PM
    ELT2JV
    17 TRD OR ACLB
    I'm on leave. Minimum effort has been my goal.
    Professional Asian and NYNURSE like this.
  9. Mar 29, 2021 at 6:57 PM
    Jordy Smokes
    Jordy Smokes New Member
    Jordy
    2012 Tacoma TRD
    JJ Diablo, Wixo and Skydvrr like this.
  10. Feb 2, 2022 at 11:08 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Im looking to with to swap my antenna for an almost nothing antenna, without having to change wires and what not.
  11. Feb 2, 2022 at 5:16 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    So strange I just came across your post . The same exact thing happened to my antenna this weekend. Nothing broken, its just really loose. Going in for 5k service next week so hopefully dealer handles it.
  12. Feb 2, 2022 at 5:23 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  13. Mar 7, 2024 at 3:07 PM
    jaapsheep
    jaapsheep Well-Known Member
    Janice
    canada
    2023 Blue Crush TRD off road access cab
    went for the blackout package this time
    I was just up there drying the roof after a spring wash, and noticed the shark fin was quite loose and I could see that water was under the rubber gasket. I am not aware of anything ever hitting it and the truck isn't even a year old yet. I don't know how hard it is to tighten it. Hopefully the dealer will do something for me as well as I'm going for my 2nd service in a few weeks. It's just been through it's first winter, maybe water got in there and froze?
  14. Mar 19, 2024 at 3:29 PM
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    anyone know the size of the nut that holds the oem sharkfin in place?
  15. Mar 19, 2024 at 4:37 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
  16. Mar 20, 2024 at 12:40 AM
    apoteker
    thanks... that's close enough to 7/8" i was able to remove it
