Removing paint transfer..what's my problem?
Discussion in 'Detailing' started by ABA180, Apr 24, 2013.
  1. Apr 24, 2013 at 11:16 AM
    ABA180
    ABA180 [OP] It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    My friend recently asked me to remove some paint transfer from her Chevy Malibu. Someone hit the right side doors and the transfer was worse as it got to the right front door.
    I own a Walmart buffer that cost about $30 and I've had it for a while now, although only using it to wax versus do this kind of work. I used that as well as some Scratch Dr which is for buffing scratches and removing paint transfer.
    I was able to remove it from the rear door and some of the front, but as it got worse it seemed to be more resistant or just not budge.
    My guess (keyword of course) is maybe the buffer I have isn't the best tool for the job. I tried some rubbing compound lightly by hand and that didn't do any better.
    What could I try? Not the end of the world, it is an older car and she isn't interested in replacing the door just trying to clean it up on the cheap if possible.
  2. Apr 24, 2013 at 11:23 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Try some wet sanding then buffing with a rotary buffer and some good compound. The "buffer" you have is what I like to call a wax applicator. That thing will never buff dull paint back to gloss.
  3. Apr 24, 2013 at 11:40 AM
    ABA180
    East Bridgewater MA
    Were I to use a better machine (like a DA polisher) would that perhaps do the trick?
  4. Apr 24, 2013 at 1:45 PM
    ntilehman
    Seth
    Charlotte, NC
    Yea a da polisher or rotary if you are skilled will get more of it out. If the paint is more embedded then try to wet sand with some 1500 or higher grit sand paper.
  5. Apr 25, 2013 at 9:15 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Just use some paint thinner... OEM clear will not be affected by it, and it should take off the transferred paint easily. It may haze the clear a little, then just polish by hand, and you're all set. Cheap, fast, and easy. Didn't think that was possible... :)
  6. May 16, 2013 at 9:51 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    Thinner works awesome to get off paint but you have to be careful of the microfibers bleeding colour. A yellow rag can dye the paint a really nasty green colour and then you have to polish that away. Which can be a pain in the ass depending on body lines/mouldings.
    Some rags do some don't so I would test a small hidden spot first before doing a big area.
