Removing rattle can paint from rims?
Discussion in 'Wheels & Tires' started by nanney1, Mar 21, 2014.
  1. Mar 21, 2014 at 7:10 AM
    nanney1
    nanney1 [OP] Active Member
    Decided to switch vehicles with my son and I'm now driving his Tacoma. He rattle canned the stock rims with black paint that is now chipping a little.
    I'd like to remove the paint, but don't want to deal with removing the tires. Would paint thinner, a rag, and some elbow grease do the trick with the wheels mounted. Or is it going to be a pain?
  2. Mar 21, 2014 at 7:12 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    its going to be a pain. any chemical that will remove the paint, will also likely damage the stock clear and graphite finish underneath. your best bet would be to sand them down properly and re-paint them, or go get them powdercoated
  3. Mar 21, 2014 at 9:10 AM
    nanney1
    Stock steel wheels, so nothing to worry about stripping. I don't think...
  4. Mar 21, 2014 at 9:22 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Run of the mill rattle can paint is a 1K paint which means it's not a catylized paint and should wipe off with a rag and laquer thinner.
  5. Mar 21, 2014 at 9:38 AM
    Detective_Dan
    Colorado Springs
    well if you're not worried about stripping, hit it with some acetone or laquer thinner and wipe it right off
