Removing/re-installing rug: trouble with seatbelt panels
Discussion in '1st Gen. Tacomas (1995-2004)' started by beedoola, May 23, 2012.
  1. May 23, 2012 at 10:25 AM
    beedoola
    beedoola [OP] Well-Known Member
    San Francisco, CA
    01' Tacoma PreRunner 2.7
    I took my rug out on my taco to clean it. I removed all the paneling to get the rug loose to remove it. All the paneling comes out pretty easy but I couldn't get the seatbelt panels off. And there is a particular spot near the floor where the rug is difficult to get out; I'm not sure if I can get it back in without taking those panels off.
    The panels start to come off but its the upper seatbelt mechanism that needs to come off- how do I take it off? Here is a pic of the cab.
    If I don't need to take the paneling off completely, how do I get the rug back under the spot in the picture - has a box drawn around it. Near the floor.
  2. May 23, 2012 at 10:27 AM
    Madjik_Man
    Colorado Front Range
    How did you remove the rug from under the panel with it in place?
    Just pulled it out?
    Can you just tuck it back under there when reinstalling it?
  3. May 23, 2012 at 10:28 AM
    beedoola
    San Francisco, CA
    yeah, just pulled it out, though it was tough getting it out in that spot and I imagine it will be even tougher getting in back in. Not sure if I even can, without taking that panel off, but I need to figure out how.
  4. May 23, 2012 at 12:21 PM
    Madjik_Man
    I just looked at the parts list diagram and don't see anything that could help.
  5. May 23, 2012 at 12:28 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I would try and un fasten the seat belt and see if the panel can be moved towards the middle of the cab allowing enough room to slip it back under, the panel near the door weather striping maybe attached some how if you try this don't pull to hard and break the panel. I would see whats involved in just removing the entire panel and hell that may not be as bad as you think. Someone on the forum did a carpet replace and may chime in.
  6. May 23, 2012 at 3:30 PM
    Madjik_Man
    I was also thinking: You should see if any guys in the audio forum can help out. I always see guys who took everything out of their Tacomas when doing a sound deadening project.
  7. May 23, 2012 at 6:03 PM
    beedoola
    San Francisco, CA
    thanks y'all. I was actually able to slide the rug back under the panel - wasn't as difficult as I thought it would be. A few of the pegs that hold the panel in fell off though : (
    Kinda poor design implementation for that particular panel - the rear panel in the back seats have better pegs that seem more rugged.
    Anyways, got the taco back together :)
  8. May 23, 2012 at 7:08 PM
    oliverlove
    oliverlove Well-Known Member
    Oliver
    Laguna Vista, TX
    01 SR5 Ext Cab
    The only thing holding that panel to the wall is the one bolt for the seatbelt, and a bunch of clips. Start slow around the window and pop that bad boy off.
  9. May 23, 2012 at 7:31 PM
    beedoola
    San Francisco, CA
    what what does the seatbelt pulley thing attach to? - the slider thing on the panel. I don't think its just a part of the panel is it? I imagine it is bolted to something else on the body.
