Removing Rear Door Handles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, Feb 13, 2010.
  1. Feb 13, 2010 at 9:15 PM
    BreezyTaco
    BreezyTaco [OP] Well-Known Member
    Corpus Christi, TX
    Pioneer Indash GPS, JL Audio Speakers, FM Alarm, Euro Tail lights, Blue Dash Lights, Trailor Hitch, Painted Fiberglass A.R.E. Tonneau Cover
  2. Feb 14, 2010 at 12:09 AM
    BreezyTaco
    Corpus Christi, TX
    I just figured it out, and it is pretty easy...
    You remove the door panel by unscrewing the screw by the inside handle and the arm rest.
    Remove the window switch and D/C the plug
    You carefully pry out the panel, starting at the bottom closest to the cab of the door, and work your way up.
    Once the door panel is off you will see one screw holding the outside handle, unscrew that with a T-30 bit, next you will see a rubber piece hiding the screw to the window guide remove that, and with a 10mm socket unscrew the bolt, then unscrew the bolt above it by the window.
    Remove the wires that are by the window slide, it is a round thing that you can D/C with your fingernail. Off to the side there are 3 bolts holding the lock mechanism remove those and the lock should fall down allowing access to the bolt holding the end of the handle or where you could stick a key in. Unscrew that and pop out the end of the handle, I used a screw driver in between the handle and the little rubber piece.
    Slide out the gripping part of the handle and replace with the new ones. After all of that is done put everything back together. Hope this helps, and is my first little write up let me know if you have any questions.
