Removing Rear Lift Blocks Have A Question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by STOCKTRD, Aug 17, 2020.
  1. Aug 17, 2020 at 5:07 PM
    STOCKTRD
    STOCKTRD [OP] Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    Going to be removing some lift blocks on the rear of a 2014 TRD Off Road 4X4. Besides new Ubolts is there anything else I will need? Is it basically remove old U-bolt, remove spacer, and then reinstall nee Ubolts. I will probably have more questions, especially when I do the fronts. I have none of the old hardware and Im trying to research what I need. Thanks.
  2. Aug 17, 2020 at 7:38 PM
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    Iirc it's as simple as remove block, lower springs onto centering pin, torque U bolts in cross pattern and check again after 50-100 miles
    gotoman1969 likes this.
  3. Aug 17, 2020 at 9:31 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Make sure the shocks you have installed won't bottom out if you remove the lift blocks.
  4. Aug 17, 2020 at 9:33 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This .
  5. Aug 18, 2020 at 6:56 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    Why you removing your lift?
  6. Aug 18, 2020 at 6:57 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Hopefully it's to put a suspension lift in...
  7. Aug 18, 2020 at 7:00 AM
    mikkydee
    Doyle
    Florida
    explain "suspension lift" difference?
  8. Aug 18, 2020 at 7:15 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Suspension lift is lift that is gained with taller/stiffer springs (leafs or coils)
    A block just moves the stock spring up higher
  9. Aug 18, 2020 at 7:24 AM
    mikkydee
    Doyle
    Florida
    advantages of suspension lift?
  10. Aug 18, 2020 at 7:27 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    More travel/articulation
    When the springs are paired with a good damper, the ride quality improves too
    RoughRder and geekhouse23 like this.
  11. Aug 18, 2020 at 7:29 AM
    mikkydee
    Doyle
    Florida
    I purchased my truck with a 6" lift on it. Back was 1.5" lower than the front. I measure the difference and added bigger lift blocks to the back to level it out. It now has 3" lift blocks on the rear to bring it level with the front.
  12. Aug 18, 2020 at 7:39 AM
    geekhouse23
    It's NOT a block and spacer lift
  13. Aug 18, 2020 at 7:41 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    A block lift is like stuffing your underwear with socks.
    RoughRder likes this.
  14. Aug 18, 2020 at 7:43 AM
    geekhouse23
    All show and no go....
  15. Aug 18, 2020 at 7:44 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    And axle wrap like a mf
  16. Aug 18, 2020 at 7:47 AM
    RoughRder
    RoughRder What fresh hell is this?
    Garrett
    Hampton Roads, VA
    2011 DCSB TX TRD
    5100s and OME 885 coils front, 5100s and AAL for the TSB leaf pack (overload left in) rear. Jeraco camper shell.
    May I use this as my signature? I'm dying laughing. Counter point, suspension lift is like taking those supplements "guaranteed" to make you bigger. :rofl:
    rlx02[QUOTED] likes this.
  17. Aug 18, 2020 at 7:49 AM
    mikkydee
    Doyle
    Florida
    Trying to educate myself here. Not my first Tacoma but the first First truck I've had a lift on. I don't take it off-road much at all. Never do any crawling or rock climbing. (I live in Florida)
    What is axle wrap?
  18. Aug 18, 2020 at 7:50 AM
    mikkydee
    Doyle
    Florida
    Doesn't everybody stuff their underwear? I usually use a cucumber
    rlx02[QUOTED] and RoughRder like this.
  19. Aug 18, 2020 at 7:53 AM
    mikkydee
    Doyle
    Florida
    Cucumbers are natural, healthy and definitely make you bigger :bananadance:
    RoughRder[QUOTED] likes this.
  20. Aug 18, 2020 at 8:03 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Google/youtube
