removing rocker/kicker interior trim
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bmgreene, Mar 3, 2010.
  1. Mar 3, 2010 at 3:10 PM
    bmgreene
    bmgreene [OP] Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Anyone know how to remove the trim along the bottom of the doors on a 2nd gen access cab?
    I'm wiring in a dash switch for a 12V socket in the bed and would like to route the wire from the switch to the pass-through under the jump seat inside the cab rather than underneath if possible.
    Tried searchalready, but the keywords are too generic to come up with what I need.
    Also, can the plastic tray in the compartment under the jump seats (2010, not sure if the compartments changed, but I know the seats did) be removed easily? After a quick look-over, it appears that the rear center console may need to come out first.
  2. Mar 3, 2010 at 3:42 PM
    MarineTacoDriver
    MarineTacoDriver Well-Known Member
    Brian
    Cherry Point
    09 SR5 4x4
    ARB front bumper, Warn M8000, ATO front/transmission/transfer case skids, Icon ext travel coilovers, Total Chaos UCA's, OME Dakar leaf springs, Bilstein/RCD 5100 3-4" lift shock, extended stainless brake lines, DrewFab shackle flip, rear ARB Airlocker, ARB air compressor
    Start pulling from the inboard side of the trim, working from one end of the piece down to the other. It's held in with plastic clips.
  3. Mar 3, 2010 at 5:22 PM
    bmgreene
    Brian
    L.A. Westside
    thanks.
    are the clips molded into the panel, or are they like door clips which connect to the panel on one side and snap into place on the other?
