Removing side gear intershaft assembly from front Diff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackSeven, Apr 8, 2012.
  1. Apr 8, 2012 at 10:48 AM
    BlackSeven
    BlackSeven [OP] Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    I'm swapping front diffs through the exchange program with ECGS and I got to this point where I'm supposed to use an SST to remove the gear and swap it to the new differential...... Uh, what can I use that is similar to this device without royal effing up anything?
  2. Apr 8, 2012 at 10:59 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I had to pop open the clam shell, then used a pry bar to basically pop it out from the bottom very carefully prying off the cross. It's only held by a retaining ring, like a cv shaft.
  3. Apr 8, 2012 at 11:02 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    This guy knows.
  4. Apr 8, 2012 at 11:04 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  5. Apr 8, 2012 at 12:18 PM
    BlackSeven
    Maryland
    I had a very long very slender punch from harbor freight and I was able to punch it out from the otherside. Was suprisingly easy, just enough force to overcome the clip, didn't leave any marks on the stubshaft.
  6. Apr 10, 2012 at 1:10 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
