Removing small piece with AUX input
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MBTacoma12, Aug 11, 2012.
  1. Aug 11, 2012 at 3:10 AM
    MBTacoma12
    MBTacoma12 [OP] Well-Known Member
    12 Prerunner DC
    I am going to put some switches next to AUX switch, how do I remove that center piece. Is it just simply pull out OR there is a trick to it.
    It's for 2012 Tacoma.
    Thanks
  2. Aug 11, 2012 at 4:00 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    You can remove that piece above the aux port easily. I did it on my 09 but i think its the same as the 12s.That piece below the stereo with the ac controls, then you gatta disconnect the wire harnesses, all you gatta do is use a putty knife or somrthing to pry it out, no screws or tricky clips. I think you can just fit you hand back there to pop the little port things out. I dont remember exactly how i did it and i had the whole head unit out when i did it and it was kinda tricky to get your hand back there and pop them out but it worked. Maybe someone else has a differet way of doing it, you might just be able to pry them out but i pushed them out from te back.
  3. Aug 12, 2012 at 5:03 PM
    PhishPhryer
    PhishPhryer Well-Known Member
    Lewisberry
    '09 Tacoma SR5
    In my '09 I just gently pried on one with a screwdriver and it came right out.
