Removing something that has been weld on
Discussion in 'Technical Chat' started by toyotatacomaTRD, Feb 3, 2011.
  1. Feb 3, 2011 at 4:03 PM
    toyotatacomaTRD
    toyotatacomaTRD [OP] Senior Member
    Hi Guys-
    This question isn't about a Tacoma, hopefully I put this in the right place..
    The dealership we bought my wifes car from removed the stainless exhaust tips and put chrome tips on.. They are terrible and are rusting, so I ordered the OEM Stainless that just bolt right on.
    My question is, the tips have been Weld on. Is there an easy way to cut through a weld? A hacksaw doesn't seem to be doing the trick... I need the pipes to remain the same size, so shortening the pipes is not an option.
    I would appreciate any suggestions.
    Thanks
  2. Feb 3, 2011 at 4:06 PM
    DAN_FPC
    DAN_FPC Well-Known Member
    Dan
    Calgary
    09 Dbl Cab TRD
    zip it off with a die grinder.
  3. Feb 3, 2011 at 5:48 PM
    toyotatacomaTRD
    Thanks.. I looked into those, but since I probably wouldn't need one of those for anything else, I am thinking I may be money ahead taking into a local place and seeing if they will grind it off..
  4. Feb 3, 2011 at 6:00 PM
    jdmbb
    jdmbb Member
    Miami and tallahassee
    06 BSP XRunner
    K&N drop-in filter, Aero Turbine 2525 Muffler on stock pipes, BFG KDW2's and TRD Duracon shift knob.
    dremel and cut off wheels? if you dont have a dremel you can never go wrong with having one.
  5. Feb 3, 2011 at 6:08 PM
    toyotatacomaTRD
    Do you think a dremel will have enough power to cut through a weld? I used a hack saw and it barely did anything..
    Harbor freight makes a Dremel knock off for $9.99.. I doubt I could go wrong. Unless it is totally worthless.
  6. Feb 3, 2011 at 6:12 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    as long as you get the right bit for it....i would try the little cut off wheels.
  7. Feb 3, 2011 at 6:12 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Nothern sells a grinder for $15 and a cut off wheel for $2 or $3.
  8. Feb 3, 2011 at 6:18 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  9. Feb 4, 2011 at 7:08 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Ha ha dremel will use $100 of cut of wheeels. its better to just go to Harbor frieght buy cheapest grinder and pack of cut of wheels.
    Total cost maybe $30
  10. Feb 4, 2011 at 7:10 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Or go to wal-mart. I bought my black & decker angle grinder from wal-mart for $20 many years ago. It gets quite a bit of use and works great.
  11. Feb 4, 2011 at 7:18 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I owned one of these and they are not very good. It had trouble cutting through a plastic model car, so I doubt it would even cut metal.
    If I was you I would just take it to a local muffler shop and have them cut the old one off and weld the new one on. It probably won't cost much more than buying an angle grinder and doing it yourself.
