removing spare tire on 2013 tacoma
Discussion in 'Wheels & Tires' started by countryhog, Oct 8, 2020.
  1. Oct 8, 2020 at 10:06 AM
    countryhog
    countryhog [OP] Member
    jerry
    NW Arkansas
    2013 tacoma 4.0, 4wd, SR5
    ok, i'm gonna ask. i've been driving and maintaining motorized vehicles for close to 60 years and never ran across this issue.
    adjusting air pressure in my tires this am and thought "oh, i'll just check the pressure in my spare". read the owners manual regarding how to lower the spare so as to check pressure. per the manual it is a totally easy peasy two step process. i may be missing something but i spent at least 30 minutes trying to get the handle to connect to the lowering mechanism, including crawling under the truck and reaching up and in with my hand to feel to mechanism; no dice.
    what am i missing? has anyone else encountered this problem? is it truly sposed to be as easy as the book says? might something be missing where to hooked rod is sposed to connect?
    as it stands now, i get a flat tire, i call AAA; totally against me grain but ya do whatcha gotta do. any help will be appreciated
    TIA, jerry
  2. Oct 8, 2020 at 10:15 AM
    RugglesTarlek
    RugglesTarlek Well-Known Member
    California
    basic basic basic 14 AC
    Shouldn't be that hard, but somewhere in here you'll find instructions for zip-tying a length of abs pipe under there that'll help with aiming the mechanism.
  3. Oct 8, 2020 at 10:17 AM
    RugglesTarlek
    California
  4. Oct 8, 2020 at 10:21 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    You may have a spare “lock” installed. It’s a smaller keyed nut similar to a wheel lock that is installed at the lowering mechanism and the corresponding key gets attached to the hook at the end of your lowering rod. If you can try and peek inside the guide tube with a flashlight you might be able to see something shiny. (The slot for the hook is painted black, while the lock kit has a zinc coating).
    whatstcp likes this.
  5. Oct 8, 2020 at 10:21 AM
    GHOST SHIP
    GHOST
    Beat me to it.
    whatstcp[QUOTED] likes this.
  6. Oct 8, 2020 at 1:39 PM
    Joe_Seattle
    Joe_Seattle Member
    Joe
    Seattle
    2002 4x4 Dbl Cab TRD 5' bed
    Just regular maintenance.
    Perfect thank you! Tire installer showed up and we couldn't figure it out. its 2020 and the spare was mfg in 2002. Brand new which is a good thing I guess. Still replacing it so they all match.
  7. Oct 8, 2020 at 5:34 PM
    countryhog
    jerry
    NW Arkansas
    Where would one of these keys be obtained. Don’t find one in my kit
  8. Oct 8, 2020 at 6:03 PM
    GHOST SHIP
    GHOST
    You’ll have to go to the dealership. They’re Toyota specific.
  9. Oct 9, 2020 at 9:03 AM
    countryhog
    jerry
    NW Arkansas
    Thanks. Got a part number? Or good description?
  10. Oct 9, 2020 at 1:49 PM
    countryhog
    jerry
    NW Arkansas
    Much todo about nothing. The hooked end goes directly into the slot. Just too simple. I tend to overthink things. Thanks for the attempted assistance. Unfortunately, you can’t fix stupid. Just sayin
  11. Oct 9, 2020 at 8:25 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    FYI mount the spare with the valve stem down. Never have to lower again to check.
    RugglesTarlek and whatstcp like this.
  12. Oct 10, 2020 at 7:14 PM
    countryhog
    jerry
    NW Arkansas
    Good idear. Thanks
