Removing Stereo Dash Panel
Discussion in '1st Gen. Tacomas (1995-2004)' started by FunWheelDrive, Feb 13, 2009.
  1. Feb 13, 2009 at 11:03 PM
    FunWheelDrive
    FunWheelDrive [OP] Member
    Hey, can you guys give me any tips for removing the dash area around the stereo? I couldn't see any screws except for something on the bottom and i don't want to pull till it breaks. Any tips or tricks? Thanks
    It's a 99 Tacoma.
  2. Feb 13, 2009 at 11:25 PM
    FunWheelDrive
  3. Feb 14, 2009 at 12:11 PM
    tmantstud
    tmantstud High Mileage Work
    Kansas City, Kansas
    98 Tacoma high mileage
    Bed liner, Polk db651s speakers, JVC head unit, Coverking custom saddle blanket seat cover
    First pull all the knobs off of the A/C Climate Control section, then remove the black plastic piece behind them. The will be 2-4 screws I forgot how many. Take them out carefully so as not to drop them behind the panel. Then at the bottom of the center console there is a plastic skirt type piece that needs to be pulled off(there are two plastic mounting pieces one on each side). Then pull off the entire plastic console( it may take some force but it will be ok). Then you will have full access to your stereo. Hope this helps
    Tmantstud
  4. Jul 1, 2014 at 8:50 PM
    dustywoods
    dustywoods New Member
    Dustin
    Redwood Ciity
    00 PreRunner SR5 Tacoma V6
    Complete camper set up, able to sleep and cook anywhere. Ridge Rider camper shell with cargo rack. 12v battery with with inverter and solar panel to charge on long trips.
