Removing stock radio
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stubbs95tacoma, Dec 13, 2011.
  1. Dec 13, 2011 at 4:17 PM
    Stubbs95tacoma
    Stubbs95tacoma [OP] Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Im taking out my stock radio and cant figure out how to get it off help me!! 95 toyota tacoma
  2. Dec 13, 2011 at 4:24 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    take the dash apart. then 4 screws are holding the radio in unbolt it then pop connectors off. assuming you know how to take the dash apart.
  3. Dec 13, 2011 at 4:28 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    yahhh no this is my 1st time taking it apart
  4. Dec 13, 2011 at 4:44 PM
    2000GTacoma
    Snow Hill NC
    o in that case in front of the shifter there should be a lower portion of the dash that has 2 clips 1 on either side. probably black pop those clips out they may break but advance or autozone has replacements. then 3 screws are removed one is located under the ashtray then 2 behind the climate control knobs. the climate panel knobs all just slide off. 1 screw on either side. disconnects the wire from the cigarette lights plugs. give a pull on the lower part of the black vent surroundings and it should pop right out. if not post up pictures and TW can look at it and help.
  5. Dec 13, 2011 at 8:04 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    take off knobs and switch caps from the climate control panel
    pop off plastic cover with the climate control pictures on them and slide out a/c button
    there should be 2 screws holding the plastic dash trim on, one at a 45 degree angle tucked up in the top left corner and one in the middle on the right side
    go to the bottom plastic piece with the cigarette lighter and that little cubby area that touches the floor and on each side there is a plastic clip, its a round plastic nail thing inside a plastic ring, push in the circle in the middle of the plastic ring and pull the plastic piece away, the plastic locking nail will fall down and you can pull out the ring, after you do that to each of them pull away that plastic piece so you can pull out the dash trim
    after those are taken out use a flat head and pry the whole plastic dash trim out. you will need to disconnect the emergency light connector and any other connectors
    you can now get to the bolts holding the radio brackets on. there are 4 bolts, 1 in each corner, tucked back in there. unscrew thoes out and bam, you can now pull out the radio.
  6. Dec 13, 2011 at 8:08 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
  7. Dec 13, 2011 at 9:19 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Not sure how much it changed from your '95, but here's a copy of the "Master Sheet" Crutchfield provided when I bought my stereo. (It's listed as being for 1998 and up Tacomas, but page 2 looks a lot like what Mark described.)
  8. Dec 13, 2011 at 9:45 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    the only difference between the 98s to 95/96s is there is not a bolt on the "power access panel",the actual whole plastic upper trim piece is smaller, and there are not 2 additional 12v accessory ports, and for some reason my 96 does not have that little cubby below the radio. its an after marketdeck but it still bolts into the same bracket as the stock radio so i dont why the hell it has a plate cover instead of the cubby. OP, or anyone with a 95/96 do you have a cubby under the radio or a plate cover? if so where did mine go.
