Removing sway bar 2016+
Discussion in '3rd Gen. Tacomas (2016-2023)' started by poopshute, Sep 24, 2017.
  1. Sep 27, 2017 at 9:30 PM
    poopshute
    poopshute [OP] Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    Not for daily driving with precious cargo (my kids). No thanks.
    hinmo24t likes this.
  2. Sep 27, 2017 at 9:31 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    A lot of people are reporting insignificant difference.
    I'll confirm in a couple weeks.
  3. Sep 27, 2017 at 9:35 PM
    poopshute
    Colorado
    Not worth the risk for me with my “stock” TRD Pro suspension. Back in my non-kid days, I removed the sway bar and didn’t think twice.
    Removing the sway bar and putting it back after a wheeling trip isn’t the issue for me. It’s removing the TRD skid plate and putting it back in that takes too much time for this to be with it. I’m going to continue to see if I can secure the bar in place after removing the links.
  4. Sep 28, 2017 at 11:57 AM
    sp-tech
    sp-tech Bone Stock
    Stephen
    2017 Char Grey Tacoma TRD
    Good call; disconnecting both endlinks and not pulling my rookie move..
  5. Oct 17, 2017 at 6:55 PM
    sp-tech
    sp-tech Bone Stock
    Stephen
    This kind of got me thinking and I may try to come up with an auto-disconnect for the sway bar... Would anyone else be interested if I came up with something?
    Carter'sTaco, ST77, MunchTIME and 3 others like this.
  6. Oct 17, 2017 at 7:07 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    My sway bar has been long forgotten. And I don’t die often.
  7. Oct 18, 2017 at 8:15 AM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Plus, with stiffer springs up front, I hear the body roll is even less noticeable.
    Voltron4x4 likes this.
  8. Oct 18, 2017 at 8:58 AM
    dorton
    dorton rockcreekoverland
    Winston Salem NC
    2016 TRD Off Road
    Old Man Emu Nitro Chargers, CS047R leafs w/ D29XL extra leaf, CBI front and rear bumpers, CBI armor, rock sliders,ditch light brackets, and bed rack, Free Spirit Recreation Extreme Series roof top tent, VTX Viper wheels, General X3 Grabber tires, 4.88 gears front and rear, Kenwood TM-710G UHF/VHF radio. Icom IC-706MKIIG UHF/VHF/HF radio,KC Hilites 20" Flex Bar and ditch lights, Safari snorkel, BedSlide Classic, SnoMaster USA expedition series fridge.
    No swaybar here for about 60k miles. No issues. Just remember lifted truck with oversized tires, roof rack, roof top
    tent, armor and a bunch of other non-stock items is not a racecar and you're fine.
  9. Oct 18, 2017 at 9:13 AM
    poopshute
    Colorado
    YES!!! Best of luck on this venture! If you need any feedback on what may or may not work, please ask. For example, simple having removable quick links won’t solve the problem as the bar itself will drop and chew into the CV joints. However, securing the bar somehow after the links are removed could be a good workaround.
    sp-tech[QUOTED] likes this.
  10. Oct 18, 2017 at 9:17 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I took my sway bar off, yes there's more body roll but its gonna take quite a bit to roll the truck, Your not going to roll the truck by just taking a quick corner, you'd pretty much have to yank the wheel at high speeds to do that, but at that point your going to have other issues like losing traction.
  11. Oct 22, 2017 at 12:42 PM
    sp-tech
    sp-tech Bone Stock
    Stephen
    I like it! I'm going to try that first and post what I come up with.
  12. Oct 22, 2017 at 12:44 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    doesn't even need to be auto just a quick release thing like all the jeeps use.
  13. Oct 22, 2017 at 12:45 PM
    Joe23
    one of my jeep friends secures his disconnected sway bar with a zip tie lmao.
  14. Oct 22, 2017 at 12:50 PM
    Joe23
    I'd be concerned with allowing the wheels to travel too much you'd over extend and damage the shocks.
    With rock crawling you might not have that harsh fast drop you'd get when going off jumps and what not but still not good to do.
    I know the shop I got all my stuff from that's strictly an off road mod shop told me sure you can get away without limit straps but really for the $200 it cost to have its a good investment in protecting your shocks. So if removing the sway bar will get you more travel you may risk more damage to the shocks.
    Just something to consider.
  15. Oct 22, 2017 at 12:55 PM
    #35
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I'd get one
  16. Oct 22, 2017 at 1:00 PM
    #36
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Regarding evasive lane change maneuvers, what is stability control like on these trucks, as good as on the 2016 hilux?
    Do ISO 3888 standards apply?
  17. Oct 24, 2017 at 2:48 AM
    #37
    poopshute
    Colorado
    Not possible unless you have spacers installed. The way the Tacoma IFS is designed, there is only so much travel available. If you were to remove the coil over up front, you would see this. There is no way to damage the shock based on achieving full travel up or down unless, like I said, you have spacers installed. Removing the sway bar just helps with achieving the full travel. Limiting straps would serve no purpose with the stock control arms.
  18. Oct 24, 2017 at 3:30 AM
    #38
    Joe23
    Ah ok. Wasn't sure for stock. But I know if you change control arms you can
  19. Oct 24, 2017 at 5:06 AM
    #39
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    That's an issue when you go long travel. So many shops think they know something when they really don't. Trust the guys that actually do this stuff. Limiting straps usually come with long travel kits.
    poopshute[OP] likes this.
  20. Oct 24, 2017 at 6:20 AM
    #40
    Joe23
    Hell the shop I got my stuff from told me for the $300 it cost I should have them on my mid travel. With the total chaos UCA it lets my fox go all the way and he said he's seen guys damage them from not having straps.
    JayRolla[QUOTED] likes this.
