Removing tailgate with camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by myirishluck, Jun 13, 2010.
  1. Jun 13, 2010 at 10:44 AM
    myirishluck
    myirishluck [OP] New Member
    Mark
    Colebrook, NH
    '09 TRD Sport
    Auto starter, Touch screen audio/navigation, push bar, Weathertech floors, Bed mat, Tonneau cover.
    Tried closing the tailgate with a load of gravel pushing back on it, and one side popped off the hinge. The camera cable grommet in the bed is out and I want to take the tailgate off to fix it. Does the camera cable to the tailgate in the '09 Tacoma have a quick connect/disconnect clip?
  2. Jun 13, 2010 at 10:52 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    yes, check behind the rear bumper area, there is a plug that you can disconnect to remove the tailgate. You should also have a cap in the glove box that you use to cover the plug if you plan on leaving it disconnected.
  3. Jun 13, 2010 at 11:08 AM
    redezman
    redezman Well-Known Member
    Charles
    Raleigh N.C
    2012 4Runner SR5 4x4
    All Factory for now, LOVE it that way
    my 08 says to unplug at drivers side tail light.
    remove tail light and you will see wiring.
  4. Jun 13, 2010 at 12:05 PM
    JKD
    JKD Well-Known Member
    epa4wd is correct. 09+ have instructions in the manual and on a couple of stickers around the tailgate to remove that plug and use the plug/socket covers included with the truck.
  5. Jun 13, 2010 at 12:30 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    It should be well documented in your owners manual too
