Removing tape on vent shades
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Jul 29, 2021.
  1. Jul 29, 2021 at 7:20 PM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hey guys need some help . Wonting to remove tape on vent /window shades . I removed one and got all the glue off but it kinda left it kinda dull . Any advice on what is the best way to buff it out ? Any advice what be much appreciated !
  2. Jul 29, 2021 at 7:23 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    I like Goof-off. Usually safe to use.
  3. Jul 29, 2021 at 7:23 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Where exactly? Pic? On the truck or the shade itself?
  4. Jul 29, 2021 at 7:39 PM
    tacoma guy
    Joe
    Phoenix Az.
    On the truck . Don't have any pics at the moment . I will try and get some .
  5. Jul 29, 2021 at 7:40 PM
    tacoma guy
    Joe
    Phoenix Az.
    I thought of that but not sure what it would do to the truck finesh.
  6. Jul 29, 2021 at 7:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I used a heat gun (hair dryer may work).
    Heated the shade/tape - be careful not to get the paint too hot.
    Then pulled the shade off. Go slow and pull it off a little at a time.
    Reapply heat, and pull some more.
    Some tape will be left on the truck.
    I also heated it, and used a plastic body panel tool to scrape the old tape residue off.
    (Kind of like a small heavy duty putty knife)
    Then finished up with 3M adhesive remover.
    After you are done. Be sure to apply a good sealer/wax to the paint.
    Kolter45 likes this.
  7. Jul 29, 2021 at 7:58 PM
    tacoma guy
    Joe
    Phoenix Az.
    Sounds good. I will give it a try . Thank you for your reply ! :thumbsup:
    TnShooter[QUOTED] likes this.
  8. Jul 29, 2021 at 8:02 PM
    TnShooter
    Deogee
    STOCK
    No problem, just keep an eye/feel on the paint.
    It took me awhile. But I finally got it off.
  9. Jul 29, 2021 at 8:29 PM
    Waasheem
    Waasheem
    2007 xrunner
    Another option, there’s a decal remover. I have one made by Astro pneumatic. It’s basically a disc, like a grinding wheel but made of rubber. I stuck it in a drill and kinda use the edge. It works great for it’s intended purpose, to remove decals. I’ve also used it to remove packing tape stuck on painted metal surfaces. You could set the drill for low rpm so it doesn’t generate as much heat on the surface.
    If the tape glue is sun baked on, goof off would be my choice.
    TnShooter likes this.
  10. Jul 29, 2021 at 8:47 PM
    tacoma guy
    Joe
    Phoenix Az.
    Will do . Thanks !
  11. Jul 29, 2021 at 8:51 PM
    tacoma guy
    Joe
    Phoenix Az.
    a
    Actually I did try that eraser wheel . But thank you for that option ! :)
  12. Jul 29, 2021 at 9:16 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    I used Xylene During my 30 plus years as a Self employed detailer and it has saved me thousands of hours of labor.
    Xylene is a fantastic adhesive remover and is clearcoat safe. The "consumer grade" removers such as Goof Off and the like are moderately sufficient at removing the weaker glues and adhesive tapes with a lot of elbow grease. Xylene can be spayed on and wiped off or put on a rag and wiped on. Xylene also dissolves road tar so fast it instantly sends it running.
    Can be found at Home Depot, Lows or any place that sells paint.
    Geeves77, JGO and Chickenfarmer like this.
  13. Jul 30, 2021 at 11:07 AM
    gotoman1969
    Good off won’t hurt the paint.
  14. Jul 30, 2021 at 6:53 PM
    tacoma guy
    Joe
    Phoenix Az.
    Thanks so much guys for all the ideas . I will try them and see what happens .
    Much appreciated !!
    Slick Taco likes this.
