Removing the 2012 4x4 selector switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mhagie, Jan 15, 2012.
  1. Jan 15, 2012 at 5:51 AM
    mhagie
    mhagie [OP] Well-Known Member
    Merle
    Washington Iowa
    2012 TRD sport DC LB
    none yet
    There is a thread on illuminating the Taco 4x4 selector switch but it has run into a snag as Toyota redesigned the switch for 2012.
    At this point in time nobody knows how to remove the switch to investigate the possibility of illuminating this switch which Toyota is too damn cheap to do on their own.
    Anyone who has access to a 2012 service manual please chime in here.
    Appreciate it.
    Merle
  2. Jan 17, 2012 at 6:14 PM
    mhagie
    Merle
    Washington Iowa
    none yet
    Anyone?
  3. Jan 17, 2012 at 6:17 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Bump; I'm interested
  4. Jan 27, 2012 at 5:32 AM
    mhagie
    Merle
    Washington Iowa
    none yet
    HELP!!!, Someone help figure this one out.
    Merle
  5. Jan 27, 2012 at 7:11 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Damn, I was at the the dealership not long ago and checked out a 12 Double Cab TRD O/R, never even thought to look at the 4x4 dial, can you post pics?
  6. Jan 27, 2012 at 7:12 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    bump for someone to help you.
  7. Jan 27, 2012 at 7:20 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    [​IMG][​IMG]
    Stereo, climate controls and vent surround has to come out to get to the switch...
  8. Jan 27, 2012 at 7:27 AM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
  9. Jan 27, 2012 at 8:11 AM
    focotacoma
    focotacoma Well-Known Member
    Fort Collins
    07 Speedway Blue 4x4 TRD off-road
    Im getting there......
    Have you all tried pulling the knob itself out of the housing. then you will have access to the mechanical switch behind it. The knob is likely glue or melted on to the switch unit and thus will take some force to remove it. You will probably have to re-adhere it to the switch after completing the mod.
  10. Jan 27, 2012 at 2:13 PM
    mhagie
    Merle
    Washington Iowa
    none yet
    Not trying to be a smart butt, but what leads you to this conclusion?
    Service manual, experience, or ??
    merle
  11. Jan 28, 2012 at 8:00 AM
    05RedTaco
    Tony
    Scottsdale
    Experience in wrenching on cars ;) I just look at the picture and I know. Trust me in order to remove the switch, you will have to remove A/C controls, stereo and the trim which houses middle A/C fans...
  12. Jan 28, 2012 at 8:14 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    OT, but is the instrument panel on 2012's backlit in blue?
  13. Jan 28, 2012 at 7:29 PM
    mhagie
    Merle
    Washington Iowa
    none yet
    I have a nephew that is a Toyota service manager in Michigan, I will contact him next week and confirm the correct method of removal, good or bad.
    Merle
  14. Jan 31, 2012 at 7:50 PM
    mhagie
    Merle
    Washington Iowa
    none yet
    Contact made, 08 White Taco is correct.
    The way is to remove the panel w/3switches (heating A/C)
    pops right out with a thin pry device.
    There appears to be two bolts holding the radio in and then two bolts holding in the complete light gray panel w/the a/c ducts.
    I removed the a/c switches and quit as it was getting late in the day and I want to do it when I can take it all apart.
    The butholes took an easy system (05-11) and complicated the hell out of it.
    Damn
    Merle
  15. Jan 31, 2012 at 8:06 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    sub'd. thanks for the info, OP!
    P.S. don't suppose you could find out how to remove the shifter knob, could you. and no, it doesn't un-screw on the 12's.
  16. Jan 31, 2012 at 10:49 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    It should be just like the 05-11. Work on pulling out the ac controls first. Then unbolt and pull out the stereo. If it dosent come out, look for bolts. Next unbolt the silver trim piece. Then you will need to pry back the black dash pieces on either side to pull the silver 4x4 trim out. Then you will have access to the 4x4 switch.
    The design is the same as the 05-11 so the assembably would also be. Just has a face lift.
  17. Feb 19, 2012 at 6:21 AM
    mhagie
    Merle
    Washington Iowa
    none yet
    UPDATE: I now have the switch removed and I can say it is a PITA.Right now it's just dangling by the wires waiting for me to decide where to go from here.
    I will update as soon as I have a workable plan, then if succesful I will update in detail or admit defeat.
    Stay tuned.
    Merle
  18. Feb 19, 2012 at 8:40 AM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Mine is white.
    I am going to have to get back there for my power sliding glass switch so i can take a look while im in there unless someone beats me to it.
  19. Feb 19, 2012 at 8:41 AM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Mine unscrews easily.
  20. Feb 20, 2012 at 10:14 AM
    DIVERMAN
    Cullen
    Louisiana
    ya, i found that out! lol. it was sloppy lose on my 09, and tight as hell on this on. i didn't want to break anything, so i thought i would ask first.
