Removing the secondary air filter.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redfish, Oct 27, 2011.
  1. Oct 27, 2011 at 10:22 AM
    Redfish
    Redfish [OP] Well-Known Member
    Is the secondary air filter the thin one thats connected to the cover of the air filter? I had to break it to remove it.
  2. Oct 27, 2011 at 10:33 AM
    Redfish
    thanks, I dont see the point of it being there. Sooner or later it will become clogged and it cant be removed without breaking it so its impossible to clean. My truck sounds much better with the pro dry filter.
  3. Oct 27, 2011 at 10:40 AM
    SPORT55
    SPORT55 Well-Known Member
    Clinton, N.Y.
    2011 Double Cab TRD Sport Black
    Agreed...The combination of the 2nd filter delete and the pro dry S replacement have been great, really woke up the sound and overall smoothness and throttle response, Love it...
    Then I added the TRD exhaust and I couldn't be happier...Not obnoxious loud and sound is perfect, sounds like a tacoma now instead of a camry :D
  4. Oct 27, 2011 at 11:44 AM
    JKD
    JKD Well-Known Member
    Unless you run without a primary air filter, I would imagine that it will be ten or fifteen million miles before the secondary air filter is clogged enough to worry about it.
    Since it has no effect on fuel economy or performance...it's kind of a non-issue. The only thing you "gain" is slightly increased emissions.
  5. Oct 27, 2011 at 11:48 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Shoulda left it alone. It was there for a reason. It's not like you gain anything from removing it.
  6. Oct 27, 2011 at 1:03 PM
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    I would leave it as it keeps your maf cleaner
  7. Oct 27, 2011 at 1:05 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    x2
  8. Oct 27, 2011 at 1:35 PM
    SPORT55
    Clinton, N.Y.
    I disagree and i'm sure the so called fact police will be chimming in, but I feel removal of the secondary filter definately smoothed out things through the power band..Which makes sense cause your taking away a restriction and in place of it are having nothing there(straight through flow).. MY OPINION , I could care less about these people who supposly checked it out....
  9. Oct 27, 2011 at 1:37 PM
    SPORT55
    Clinton, N.Y.
    If it were there for a reason then it woul be used when you install aftermarket cold air intakes, which it's not...
  10. Oct 27, 2011 at 1:48 PM
    SPORT55
    Clinton, N.Y.
    Another thing that cracks me up is....Oh it helps the 4 but not the 6 cyclinder, what a load of crap.. Please tell me oh wise ones that say this, how does it help one and not the other,,,what a joke..
  11. Oct 27, 2011 at 1:56 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    no because the point of an aftermarket intake is to increase air flow. they are not there as a "factory replacement". they are marketed as an upgrade.
    because they are different engines.
  12. Oct 27, 2011 at 2:37 PM
    YodasYota
    YodasYota I'm here for the chicks.
    Yoda
    Orange County CA/the Dagobah system
    White 2005 2.7L
    aFe pro dry s drop in, secondary air filter delete, "Black Box" mod, debadged, tinted windows, Hawaiian print all weather seat covers, rubber all weather floor mats, 300mm Broadway rear view mirror, hyper yellow headlights, surf wax melted in, on and around the bed (shes dirty), LED brakes, side markers, rear turn signals, license plate, and interior lights. A cracked tail light that I fixed with some tape, 235/75/15 All Terrains. $$$$NearFuture$$$ Alloy 15x8's, DT headers, upgrade speakers and head unit, THULE bed rack or a ladder rack. Than I think I'll be pretty satisfied.
    I think I saw a post where someone even cut a hole in there air box. Silly
  13. Oct 27, 2011 at 5:35 PM
    SPORT55
    Clinton, N.Y.
    I don't own a k&N intake,, and facts aren't facts cause you say they are
  14. Oct 27, 2011 at 5:39 PM
    SPORT55
    Clinton, N.Y.
    Show me your research... And I never once said I picked up HP from the filter delete. MAybe you should reread.
  15. Oct 28, 2011 at 1:23 AM
    Maverick904
    Kameron
    Northeast Florida
    You sir are the one who needs re-reading. I never once said anything about you claiming to gain HP..
    my comments come from this post..and another simliar one.
    looks like a butt dyno comment to me.
  16. Oct 28, 2011 at 11:20 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    You're right - Gadget doesn't know what he is talking about. :jerkoff:
    Fink
  17. Oct 28, 2011 at 11:50 AM
    Fink
    Orlando, FL
    So listen, I am going to ask you this with sincerity...
    Do you honestly think that what Gadget, and other very knowledgeable posters (not based off post count) have presented you with is incorrect?
    Again, I am asking this not as a troll, but as an inquisitive mind.
    Fink
  18. Oct 28, 2011 at 11:55 AM
    SPORT55
    Clinton, N.Y.
    Certain things yes and others no, Just cause people have alot of posts doesn't qualify them as experts in my opinion..In my experience these people are more like followers, spreading the words or so called facts of others and have NO real results for themselves... I think thats sums it up well...
  19. Oct 28, 2011 at 12:00 PM
    SPORT55
    Clinton, N.Y.
    Um actually it was 540 hp in stock form and the main HP was produced by the eaton blower on it, later changed to a TVS ( that I installed)...
    Can I further assist you in learning more about the shelb before you speak?
    :violent:
  20. Oct 28, 2011 at 12:02 PM
    SPORT55
    Clinton, N.Y.
    Yes I do feel his results COULD be in inaccurate...
    I like to get Fact by my own eyes not others words...
    Should we keep beating this dead horse or what?
