Removing the shift lever
Discussion in '1st Gen. Tacomas (1995-2004)' started by JudoJohn, Jul 27, 2014.
  1. Jul 27, 2014 at 1:23 PM
    JudoJohn
    JudoJohn [OP] Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    What is the trick to remove the shift lever from a 5-speed transmission? I am in the process of trans removal for a clutch assembly change. I have the boot removed and can see the spring around the shift lever, but I cannot figure out what needs to move or how to get the lever out.
    Please help!! yes, I did a search.
    thank you.
  2. Jul 27, 2014 at 2:15 PM
    havenoclu
    havenoclu Member
    After the retaining clip is out, it should just pull out.
  3. Jul 27, 2014 at 2:24 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Push down and twist, then it pops out.
  4. Jul 27, 2014 at 2:47 PM
    JudoJohn
    St. Louis
    I don't see a retaining clip.
  5. Jul 27, 2014 at 2:48 PM
    JudoJohn
    St. Louis
    right or left, or does it not matter?
    Thanks
  6. Jul 27, 2014 at 4:29 PM
    lt thistle
    lt thistle Member
    Oregon
    02 3.4L SR5 TRD
    I believe it will only turn one way
  7. Jul 27, 2014 at 5:07 PM
    havenoclu
    havenoclu Member
    Push down, turn left. It's a bit of a pain the first time
  8. Jul 27, 2014 at 7:45 PM
    Combatman
    Combatman Well-Known Member
    Sioux Falls sd
    1996 Tacoma 4x4 3.4 Manual
    31" Wrangler tires
    It sucks even more putting it back it, the metal around the outside always cuts my thumbs up
  9. Jul 28, 2014 at 7:33 PM
    JudoJohn
    St. Louis
    I could not get it move, so i removed the 6 bolts holding its housing to the tranny. It went back in easily.
  10. Jul 28, 2014 at 7:36 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    use a rag. Interestingly, they even call it out as the SST in the FSM, if I remember correctly.
  11. Jul 28, 2014 at 8:23 PM
    havenoclu
    havenoclu Member
    I could see a rag working well
  12. Jul 29, 2014 at 4:48 AM
    68dave
    Dave
    I always push down with needle nose pliers and twist. I agree installing it is a PITA.
    1997tacomav6 likes this.
  13. Jul 29, 2014 at 4:54 AM
    tomtom
    The Desert SW
    2012 FJ
    Using your thumbs and a cloth to provide some cushioning and grab, it is actually fairly easy.
    Push down and CCW to remove.
    Push down and CW to install.
  14. Jul 29, 2014 at 8:23 AM
    Madjik_Man
    Colorado Front Range
    I was almost brought to tears trying to reinstall it.
  15. Jul 31, 2014 at 3:31 PM
    68dave
    Dave
    Do yourself a favor and replace the shifter ball bushings while you have it apart. Marlin Crawler or your local dealer has them.
