REMOVING TINT
Discussion in '1st Gen. Tacomas (1995-2004)' started by surfermatt, Mar 3, 2011.
  1. Mar 3, 2011 at 6:03 PM
    surfermatt
    surfermatt [OP] Well-Known Member
    CA
    04 prerunner, ext cab
    Front long travel custom: king 10" CO, solid lowers, fabbed spindle, heimed everything ect. Rear still in progress, waiting to be put on: bilstein 9100s, T100 axle. Stock 3.4 engine, 4.30 gears.
    Ive tried searching but couldnt find the answer. The last owner of my truck put a weird clear film up front to protect from UV or something. I want to put 20% on but i need to take this off first. What would be the best method of removing it?
    thanks in advance...
  2. Mar 3, 2011 at 6:08 PM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    scraper (essentially a razor blade) and oven cleaner is what i used back probably ten years ago.
  3. Mar 3, 2011 at 6:19 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    all the above!
  4. Mar 3, 2011 at 9:02 PM
    surfermatt
    CA
    cool thanks! ima do it later this week... theres a shop down the street incase it doesnt come out clean lol
  5. Mar 3, 2011 at 10:18 PM
    surfermatt
    CA
    sounds good, if its cheap enough ill have them do it so i dont have ta worry...
    how easy is putting it on? seems simple enough
  6. Mar 4, 2011 at 7:51 AM
    surfermatt
    CA
    yeah ill get prices from my local shop, ebay sells pre cut one for 8-25 dollars, but if im having them remove it i might as well have them put it on too
  7. Mar 4, 2011 at 7:54 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    The last time I had tint removed from a window the guy used a heat gun carefully and a razor blade scraper.
  8. Mar 5, 2011 at 7:18 AM
    surfermatt
    CA
    used a razor and acetone for all the glue left over, came out sorta clean...
    i had a shop put it on for me and the got the residue of the same way but alot faster haha
  9. Mar 5, 2011 at 7:35 AM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    Get a trash bag and try to find some glass cleaner with ammonia in it. spray the window really good with the cleaner and then stick the trash bag to it.. let it sit in the sun or use a heat gun for 20 minutes.. the tint should come off with the glue quite easy after that. If you have rear defrost look out cause a razor will mess it all up..
  10. Mar 5, 2011 at 3:10 PM
    ScottyB
    ScottyB Well-Known Member
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    Previous owner of my truck put tint on that looked DIY and did a crap job of it. I also couldn't pass a state safety inspection without removing it or paying extra for someone to "overlook" it. Took it off with a razor blade but it left A LOT of sticky shit that I ended up cleaning off with a combination of goo gone and wd-40, elbow grease, rags and more razor usage. Major pain in the ass because the film coming off totally separated from the sticky junk that held it there.
    After reading these responses maybe a heat gun would have been a good idea. Or maybe a hair dryer since I don't have a heat gun anymore hah. Either way I got it totally clean, just took a couple hours.
  11. Mar 5, 2011 at 9:01 PM
    surfermatt
    CA
    yeah took me about that long as well, killed my arms n razor but its clean now :)
    only thing is i got 35% and now wish i went to 20% :(
    whats the laws for all that in hawaii?? im moving there in september but am not sure if im bringin my truck
  12. Mar 6, 2011 at 4:02 AM
    ScottyB
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    35% is legally the darkest you can go on your side windows. nothing on windshield is legal, rear windows i think depends on type of automobile. you need an annual safety inspection which is usually $15. $5 more if you have tint and they need to get out their meter to stick on your windows. some places will pass you if you had your tint installed at a real shop that gave you paperwork for it so it doesn't need testing.
    there are tons of people that have darker tint that i see driving around. i was never into it so i haven't bothered finding out how they get away with it. the cops here don't pull over people for tint regularly here like they did when i lived in LA though so its just a matter of passing the joke of a safety check.
  13. Mar 9, 2011 at 9:07 PM
    surfermatt
    CA
    :D
    cool man, glad i got 35% haha
    what about theft n breakin into trucks??
    im moving to manoa on oahu but i surf n dive so ill be all over oahu i hope:D... when ive been down there i always see tacomas all over but dont wana run into any problems ya know...
