Removing Tonneau Cover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KYCatFan, Aug 29, 2017.
  1. Sep 3, 2017 at 12:22 PM
    imdav2u
    imdav2u Well-Known Member
    St. Louis
    2016 TRD Offroad DCSB 4X4
    I'm in the midwest if anyone has one for sale.
  2. Sep 3, 2017 at 12:27 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    pretty easy, just unscrew the bolt, fold and clip the panels and have someone help you lift the cover up.
  3. Sep 3, 2017 at 2:52 PM
    rodrigger
    rodrigger Active Member
    Canada, BC
    2017 Tacoma TRD Sports Upgrade
    when I had oem tonneau installed on my truck, I made sure I got my original plastic bed rails back, apparently I have been told that dealership just throw them out in the garbage if you don't ask for it. So now I have original rails sitting in my workshop and can reinstall back if I decide to sell the tonneau cover with the oem cutoff rails. So guys always ask for your "ORIGINAL RAILS" back.
  4. Sep 5, 2017 at 4:08 AM
    Jleeb
    Jleeb Well-Known Member
    Vermont
    2017 DCLB OR SUPERwhite.
    Stock
    My trucks cover was factory installed and there are no original rails...unfortunately.
  5. Sep 13, 2017 at 5:59 PM
    Jleeb
    Vermont
    Stock
    Is there any cap of sorts that I need to cover where the bolts currently are or will an uncut bedrail cover that void?
    Am I understanding correctly that I have to 1). remove the tonneau cover itself.
    2). Remove the 6 bolts/mounts.
    3). Remove the rubber plugs closest to the cabin?
    4). Install uncut bed rails.
    Am I missing a step? Thank you for your help!
  6. Sep 13, 2017 at 6:02 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    No bolt caps needed, the rail caps cover the holes. You got it pretty much-
    Also remove the forward support from the front middle of the bed, right below the slider window. Stock trucks just have empty holes there. If you want to fill them, put in other bolts or plastic caps (True Value has them).
  7. Sep 13, 2017 at 6:04 PM
    Jleeb
    Vermont
    Stock
    Thank you. So the only plugs that need removing are closest to the cabin, correct? I've seen some picture of folks plugging some gap near the tail gate when installing a cover and got thoroughly confused.
  8. Sep 13, 2017 at 6:11 PM
    OnHartung'sRoad
    That gap is in the 2 front corners between the sides and front bed walls after you put the new caps on the side rails- my ARE camper shell installer used black adhesive foam to seal it, but black silicone would work too.
    Jleeb[QUOTED] likes this.
  9. Sep 15, 2017 at 7:07 PM
    Jersey Blues
    Jersey Blues Member
    Jerry
    2017 4x4 crew 6ft bed blue
    Similar situation here in Edison, NJ. Just bought a 2017 Tacoma long bed with an unwanted OEM Tonneau cover. Want to put on a cap, and don't want to put cover in garage loft eternally. Anyone want this cover locally can have for $250 and their rails.
  10. Dec 5, 2022 at 10:24 AM
    goshgo27
    goshgo27 Well-Known Member
    Rich
    2016 Tacoma TRD Sport (double cab)
    center console organizer MBRP exhaust Automatic tailgate lock
    Apologies if this is bad forum etiquette (responding to an old thread) but I am a little confused about something and was hoping for clarification. I just purchased the TruXport roll up cover and plan to replace my OEM rigid cover. It was hard to decide between the truXport and the LoPro but based off this thread, I may have made the correct choice. I went to install it last night and quickly realized that the brackets could not slide into the tracks because the locking bolts that the rigid OEM cover clicks into are in the way. My plan was to remove the top rails to get access to the locking bolt hardware, remove them, and then reinstall the bed rails with the cut outs. If I bought the LoPro, which mounts next to the bed rails, I would understand why new bed rails are required but since the TruXport mounts on top of the rails, I assume I am OK, because it will completely cover the cut out portion. Does this make sense or should I drop more money for new rails?
    Thank you!
  11. Dec 5, 2022 at 12:16 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, makes sense. But iffy that it will cove the cut outs. New rail covers are around $150 each. Just removed my oem cover and went with Bakflip MX4.
  12. Dec 5, 2022 at 12:30 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Living here in new england i was constantly having snow fill up my trucks beds, plus the rest of the year it'd rain getting anything i had in the bed wet....what a pita. Told myself i was getting my next truck installed with a tonneau cover. It was the best thing i did. The factory folds right up, and comes right off with one bolt when needed. Can't get much easier.
  13. Dec 5, 2022 at 1:23 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Sounds like it would be off your truck a good bit. But still, if it were me i would take it off (one bolt!) and store it. They absolutely do come in handy.
    zoo truck likes this.
  14. Dec 6, 2022 at 9:42 AM
    goshgo27
    Rich
    Thanks Man, and I checked out the Bakflip, which is similar to the LoPro in that it sits next to the top plate. The truxport sits directly on top and covers all but 1/8 of it.
  15. Dec 6, 2022 at 9:48 AM
    #35
    Andrew.arw
    Andrew.arw Chief Beer Officer
    South Carolina
    2018 Toyota Tacoma TRD OR 3.5 V6
    *** Current Setup - 2/27/24 *** - Wheels // Method 316, 17” - Tires // 275/70/R17 // Falken WildPeak A/T4W - Suspension // 2.5” lift // Eibach’s Pro lift, Stage One - front & rear // Eibach Pro Springs // Icon AAL // TC UCA’s - Lights // Rigid Industries Dual Pod’s [Grille] // Rigid Industries Dual Pod’s [Rear Bumper] // Rigid Industries 40” LED Bar [Roof Rack] // XenonPro Hi/Lo Beam // LASFIT Switchback Fogs - Auxiliary // Switch-Pro controller, SP-9100 Series - Audio // Rockford Fosgate R500X1D Amplifier // Dual Rockford Fosgate P1 10" Subs - Accessories // TRD Pro Grille // Prinsu Roof Rack // Rough Country Soft Tri-Fold Tonneau - Armor // Body Armor Rear Bumper, 4x4 Desert series // TRD Pro Skid Plate - Misc Mods // ECGS Bushing // Cali Raised AC Drip relocate // CMC
    As others have mentioned, it’s very simple.
    Also, you can easily sell that. I believe they were an 800$ add on? Someone will prob throw a few bucks your way for it. I’d buy it if you were local, and I already have one. :p
  16. Dec 10, 2022 at 5:44 AM
    #36
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    My 2022 Tacoma came with the tri-fold factory tonneau cover, I really didn’t want one but came that way and was about $800 added to the sticker price. I find the thing just about useless. I’ve taken it off and back on several times in order to load different things. It weighs about 85 pounds and is cumbersome to handle. It’s kinda of a catch 22, my mileage improves with it on but when I need to haul/load something, I have to take the damn thing back off again. Now it stays off, I’m tired of screwing with it.
  17. Dec 10, 2022 at 5:49 AM
    #37
    na8rboy
    WI
    That's why I switched to MX4. It opens, all the way. OEM, opening only 2/3's the way is poor design.
    atc250r likes this.
  18. Dec 10, 2022 at 5:52 AM
    #38
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Just curious because I don't have the OEM tri-fold cover but the Undercover tri-fold cover. Does the OEM cover not have a provision to prop up the last panel to give full bed access?
  19. Dec 10, 2022 at 6:50 AM
    #39
    zoo truck
    None
    Dealer charged me about $650 for the factory tacoma tri-fold cover.
  20. Dec 10, 2022 at 6:53 AM
    #40
    zoo truck
    None
    No, you need to remove the cover if you want full access. With a 6' bed i have, the oem cover works out well for most my needs.
