Removing TRD offroad decal/sticker
Discussion in 'Detailing' started by 169.254.255.201, Mar 3, 2013.
  1. Mar 3, 2013 at 11:41 AM
    169.254.255.201 [OP] Well-Known Member
    Interwebs
    Hey, was wondering if anyone has any suggestions on removing this.. [​IMG]
    Its on the side of the bed, and I am going to put a decal from sockmonkey in place of it in a few weeks. I don't know how strong they are, and if I need to be worried about damaging the paint. Maybe run some warm water?
    Before I put the new decal on, anything I else I should do other than washing, and waxing the area considering I won't be able to for years?
    For anyone interested in the decal I plan on getting from Sockmonkey, this is it. [​IMG] That is how it will look on my truck. Approximately. and this is how it looks without a truck behind it per se. [​IMG]
    Ask for mirrored flags in flat black vinyl. and they are 10" wide and will run $13 for the pair (shipped) from sockmonkey. I'll post pictures once installed!
  2. Mar 3, 2013 at 11:45 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Hair dryer to heat it up. Should pull off. Might have to continue to heat a bit as you go. Goo gone to remove excess adhesive that remains.
  3. Mar 3, 2013 at 11:50 AM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Cool Post Bro, Tell TJ Hunt To Update The Vlog!
    Ive done this before. I used a hair dryer to heat the decal up. Then slowly peeled it way. After the decal is gone I used Goo Gone to remove the residue. Finally I cleaned the area with dishwashing soap and water.
    Dont use a plastic scraper, it will leave scratches. Go slowly and take your time. The hardest part is removing the residue, it takes awhile and requires alot of patience.
    FYI when you are installing your flag make sure the blue union square always faces the front of the truck. This is how its done on USAF aircraft. It makes the flag look as if it is moving forward to the enemy.
  4. Mar 3, 2013 at 11:52 AM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    03 Double Cab SR5 TRD
    Debadged. AFE Stage II intage. Magnaflow muffler. Mid travel. Blackrocks with BFG AT
    I like this idea. Kind of want to do it to mine as well.
  5. Mar 3, 2013 at 12:20 PM
    Interwebs
  6. Mar 9, 2013 at 9:37 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I used the pressure washer at my local car wash. Just point the tip about a half inch away and watch it fly. Be carefull if the tip does not have a rubber end piece. Took about 2 minutes each side and no paint damage
  7. May 26, 2013 at 9:20 AM
    B2BTaco
    B2BTaco Well-Known Member
    Brian
    U.S.A - Alabama
    Tacoma - TRD Sport 4X4 - Silver
    Bilstein 5100 Series Shocks (Front) raised 2.5 inches. Pro-Comp AAL 1.5 inch raise in rear. HomerTaco Thin-Lip Satoshi Grill. AVS Bug-Deflector, Front Two Windows Tinted (to match factory tint on back windows). Baja Roof Basket with Spare Tire Carrier. Shorty Radio Antenna-black. Cobra CB Radio/PA System installed. De-badged (all Toyota/Tacoma decals gone). Front & Rear Mud flaps removed. STEALTH 3157 Taillight bulbs (removed amber bulb for cleaner look)
    Did you get your decals from sock? Why is it most pictures I see this guy post are down or won't pull up? Seems sketchy. I love his work though. Just wondering if it ever made it on the truck and how it looks considering this was 2 months ago.
  8. May 26, 2013 at 10:09 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    He's not able to make them anymore, think he lost access to the equipment. That may explain why pics are down as well. Not sketchy, he's been around a long time.
